3" y pipe???
Old May 19, 2006 | 01:05 PM
dirtyred92's Avatar
3" y pipe???
i own 92 camaro 5.0 trying to find a 3" y pipe does anyone make one or do i have to custom it?
Old May 19, 2006 | 03:46 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
You mean with three inch inlets or outlet.
Old May 19, 2006 | 10:09 PM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
ur having a hard time finding a 3inch y-pipe because i'm pretty sure i doesnt exist, i installed my 2.5inch y-pipe from hedman and the pipe is almost rubbing againts the oil pan, but my headers have a 3inch collector, it's all about clearance, if u go custom better mesure right, theres not alot of room, trust me ur better off getting a good header and y-pipe kit, less of a pita
from my exp. hedman is good for the money u pay
Old May 22, 2006 | 10:42 AM
dirtyred92's Avatar
3 " inlet and outlet i got 3" collectors on my headers
thanks i will go custom i guess will post when done
Last edited by dirtyred92; May 22, 2006 at 10:43 AM. Reason: Automerged Doublepost
Old May 22, 2006 | 10:51 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
It will be tight putting a 3" y-pipe in the car, like tsibouky said the 2.5" pipe is very close to the oil pan I have the same y-pipe as he does and I'm for sure that a 3" will be hitting the crossmember and the oil pan. From there I went to a 3" i-pipe and everything worked out pretty good.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
