dumb question
Old May 23, 2006 | 02:09 PM
bfox88's Avatar
Car: 90 IROC-Z
dumb question
im blowing whitish/grashish smoke out of my tailpipes and believe it is the smog pump, i just want to make sure that the smog pump could be the cause of this problem before i go pulling it and buying a new one. so can a bad smog pump be the culprit of my whitish/grashish smoke thats being blown nearly all the time?
Old May 23, 2006 | 02:26 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
whitish/grayish would indicate that coolant/water is getting into the combustion chamber. you've got bigger issues than a screwed up smog pump.
Old May 24, 2006 | 01:49 PM
bfox88's Avatar
Car: 90 IROC-Z
are you sure? is there any way i could fix that? wow, now i'm really worried.
Old May 24, 2006 | 02:18 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
When does it smoke? All the time, or just on startup? If you can, go and see what the smoke smells like also. Very easy to tell if it is coolant or oil.
Old May 24, 2006 | 03:35 PM
bfox88's Avatar
Car: 90 IROC-Z
it smokes on startup, then when running when i get on the gas.
i'll smell it later.
my god i really hope it isnt a blown gasket or something or i'll be devestated. thanks for your help and keep it comin please
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
