O2-sensor question
Car: '91 Z28
Engine: LB9
O2-sensor question
I have now some hedmans installed. The O2-sensor sits at the end of the header next to the flange to the y-pipe connection.
Is this location to far away?
The sensor is throwing a code and I'm not sure if the sensor is broken or the location is too "cold".
Would switching to a heated sensor help any?
Patrik
Patrik
Transmission: 4L80E/4L80E
Shorty style headers, right?
Shouldn't be a distance problem for the sensor. Either wiring or bad sensor. Did you put in a new one when you put the headers in?
Car: '91 Z28
Engine: LB9
Yes, shorties
No, it's still the old one in there.
The mechanic told me that he had no problem taking it out so he was positiv that this one still works.
But its still the first sensor I think...
On the other hand, he told me that there was an extension wire with the installation kit. This could be also a problem!?
Make sure the connections are all snug. If so, I'd guess you need a new sensor. The old one could have been on the edge before the headers, and now is over the edge.
Car: '91 Z28
Engine: LB9
ordering a new sensor would probably be the best anyway, so I'm sure that all is in perfect condition.
Thanks for your help!
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Just wanted to give you a heads up... I would order an AC Delco sensor. Those $20 Bosch sensors that you can get at AutoZone are just terrible.
Car: '91 Z28
Engine: LB9
So I ordered an AC Delco et voilą: runs smooth and no more ses lights!
