2.5" or 3"? Which do I really need
Old Aug 3, 2006 | 07:11 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey all. I've got an 84 Trans Am with a little carbureted 305. I want to get a set of headers...I've been looking at the Hooker 2055's but here is my dilemma. Later this fall or maybe early spring (depends on cash flow) I'll be putting in a 383. If I buy the headers with a 2.5" collector, they'll fit my stock exhaust but will the stock 2.5" single exauhst be enough for a 383? Or, should I buy a 3" set of headers and get a reducer until I can afford the rest of it? How much performance would I honestly lose and more importantly, would it hurt the motor at all if I stuck with the 2.5" set up? Any info at all would be greatly appreciated. Thanks!
Old Aug 3, 2006 | 07:17 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
With a 383 I'd definitely use 3", especiallly for the Y Pipe.
I've got 2.5" headers on a ZZ4 350 and they are choking it. If I had an extra $600 the first thing I'd do is put in a set of 3" headers and y pipe.
Old Aug 3, 2006 | 07:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
So for the time being...since I don't have the motor finished yet, I should buy the headers with 3" single out at the y-pipe, and just stick a reducer on it until I get the new motor and new...I guess I'd call it a cat-bac...system in?
You know, I started this motor plan, but then it morphed to needing exhaust, needing suspension, needing this, needing that. Ugh! lol
Old Aug 6, 2006 | 09:29 PM
92comaro/conver's Avatar
Car: 92 comaro-rs
Engine: 3.1liter/supercharged350 comingsoon
Transmission: 700R4 trans.
Iwould run 3" headers with 2.5" reducer until you have some chedder to do the rest,but i agree with other guys you should run 3"all the way. i dont run a y pipe on my 383" i run a dual inlet&outlet high performance cat.( custom exhaust) that is just me p.s im new to this site how to you put your vech.transmission.motor and other info
Old Aug 6, 2006 | 09:48 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
the 2.5" collectors will work if you run dual 2.5" pipes. No V8 should have less than a 3" single pipe, imo.
Old Aug 7, 2006 | 07:47 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Well that settles the argument then. It's headers with a 3" collector after the Y-pipe to a reducer and my 2.5" stock exhaust. Now...to get it ceramic coated or not! lol
Old Aug 7, 2006 | 11:37 AM
mdricken's Avatar
Car: 92 Camaro
if you've got the money for it
But I would invest in other more necessary things like
headers, trans, carb, tires, etc
