o2 Sensor?? Help please
Old Sep 8, 2006 | 09:01 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Hey guys, i am having a real hard time getting my old o2 sensor out of my car. it is lefty loosy righty tighty, or is it a reverse thread? i have tried everything, even when the exhaust was hot! I'm about to get my blowtorch out >.< i don't know if it is the original, but it has a purpleish wire from it. I have used wrenches and vise grips... this thing just does NOT want to move
Anyone else experience this problem?
Old Sep 8, 2006 | 09:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's normal thread.
Old Sep 8, 2006 | 09:50 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
spray some of that lube crap on it wait a couple minutes and try as hard as you ****ing can. i had my manifold off and had to put it in a vice and use channel locks to get mine out.
Old Sep 8, 2006 | 10:12 PM
mbrownone's Avatar
Car: 3rd Gen Trans Am
spray wd40 let it soak in and spray again and then maybe again before waiting a few minutes and try to remove...but be sure to spray it when the engine is cool
Old Sep 10, 2006 | 07:48 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
thanks for the help guys
Old Sep 10, 2006 | 11:25 AM
subliminal's Avatar
Dont use wd40 use PB blaster
Old Sep 10, 2006 | 11:34 AM
gray89vert's Avatar
Engine: 305 TBI LO3
yea wd40 isn't for breaking anything loose...its just to stop squeeks and lubricate a little. pb
Old Sep 10, 2006 | 11:44 AM
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
You said removing your old O2 sensor, so I am assuming that you are replacing it with a new one. If the lube/ penetrant spray isnt effective, I would remove the connector and use a torch to heat up the threaded nut that the sensor threads into. When it is glowing red get your wrench, or even better, one of those sockets for O2 sensors and apply leverage. Over the years rust and corrosion have built up on the threads beteween the sensor and the pipe. Heating that part of the pipe up will cause it to expand slightly larger then the threads of the sensor which will allow it to break free. Working with older exhaust systems can be a PITA sometimes. Hope that I could help. -Bob
Old Sep 15, 2006 | 07:43 AM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
I would soak it in PB Blaster for a couple nights, then get the engine nice and hot running. Kill the engine and jump in there with an O2 socket and get yourself as much leverage as possible. You should be able to get it with enough leverage.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
