catalytic converter
Old Oct 13, 2006 | 09:31 PM
hbranontn's Avatar
catalytic converter
The catalytic converter on my 88 GTA is rattling like crazy....Should I replace it or cut it off and replace with straight piece of pipe....What will I gain or lose by just replacing with pipe?
Old Oct 15, 2006 | 12:17 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
That is probably just the heat sheild rattling. You can shut it up with a paper clip if you wanted something cheap, and didnt have access to a welder.
Maybe gain 3HP by running a straight pipe, but alot of third genners are against this, and you can get in alot of trouble as it is against the law to do so. IF you do it though, just weld up your heat sheilds to the run-through pipe to make it look like its still on there for visual inspection.
Old Oct 15, 2006 | 03:02 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Could be the heat shield rattling but it could also be the stuff inside the cat has come loose and is rattling around. Thats what happened on mine.
Old Oct 15, 2006 | 08:08 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
yea mine did that so i cut it out.... but in canada you dont need a converter in these cars... if you live in the states... from waht i hear you need to pass emmisions testing or something so you should look into that before you do
oh... forgot to tell you.. if you jsut cut it out and put a piece of piping in... when you rev your car it will backfire.. you might want to keep the cat or get a new one
Last edited by dave-92gta; Oct 15, 2006 at 08:12 PM. Reason: Automerged Doublepost
Old Oct 15, 2006 | 08:57 PM
That might only be because your weld isnt completely sealed. If you have left holes, then that is what is causing your backfiring. If you clamped it, well then that is definately it. Just get a better weld in there.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
