long tubes or shorties if i plan to lower?
Old Oct 31, 2006 | 11:28 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Which should I go with if i plan to lower my car. I've heard long tube scrape. I had planned on getting long tube hedman headers from summit. What should I do?
Old Oct 31, 2006 | 11:37 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
all i can tell you is that the hooker super comps scrape with eibach spotline springs.. just gotta watch for the speed bumps.. and the layout of your exhaust will be a factor as well.. if you use long tubes.. thats just from my experience.. true duals with hooker supercomps..
if you dont go offroading, or see alot of speedbumps, i would say go with the long tubes.. better for making power down the road..
Old Oct 31, 2006 | 11:58 AM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
i heard from someone on here that even the hooker shorties will drag since they're y-pipe is extremely low to begin with, and add that to a ~2" drop, it will drag.
But this isnt from experience so just think about it.
Old Oct 31, 2006 | 12:59 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
What kinda power are you looking for???
i will keep it simple.
<400 = shorties
>400 = longtubes + pain in the *** to get them to not scrape.
i have longtubes hookers, and a true dual 3" pipes. Cost me next to nothing to build it, but it is super loud and scrapes a bit.
I am buying a mufflex Y pipe and a single 4" asap.
Old Nov 22, 2006 | 10:45 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
shorties cant handle more than 400hp?
Old Nov 22, 2006 | 10:50 AM
Engine: LS3
Of course they can. They dan handle 2000HP if you want, but you are going to start noticing a power loss due to them around that ball park. It also depends on where you are making that power in your RPM range. Also primary size is a huge factor as well. There is such thing as a pipe that CAN'T take whatever horsepower, it just hurts more than you might want.
If you read a couple books about moddifying cars, it all becomes very very very clear. If you still don't get it by just thinking about it. (most people don't)
Old Nov 22, 2006 | 01:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
99% of the people out there are incapable of making over 400rwhp with the commonly availible shorties for 3rdgens without a power adder.
and since IMO a performance motor for a camaro STARTS at 400rwhp and goes up from there, if its for performance, the only realistic choice is longtubes.
the headers themselves are not bad.
its just that people do not take the full effort required toward making room for the exhaust. so their exhaust scrapes.
if you build a trans crossmember that has passthrus for the exhaust pipe, you wont have a ground clearance problem.
Old Dec 9, 2006 | 05:51 PM
L.I.N.Y.92CAMARO's Avatar
even with the slp 1 3/4 you cant make over 400rwhp? I find that hard to believe. I think it will just lower your curve of power a little more. I may be wrong.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
