Y pipe
Old Nov 28, 2006 | 07:48 PM
pairtoe's Avatar
Y pipe
what are the benifits of having a y-pipe?
im putting headers on my car and wanted to do a custom true dual exhaust, headers then exhaust cutouts then 2.5" pipe to two glass packs. the headers i bought came with a y pipe, but would it be a problem not to use it?
Old Nov 28, 2006 | 08:32 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
If you're doing dual exhaust you don't use a Y pipe, a Y pipe is meant to merge 2 pipes into 1. If you do duals you would usually install an H or an X pipe to equalize pressure in the 2 banks of exhaust. I will tell you this, I put duals on my car and if I had the parts on hand to just run a 3in single exhaust I probably would've been happier with that. Running the duals for me lost me some ground clearance.
Old Nov 28, 2006 | 08:36 PM
pairtoe's Avatar
do i have to run a h or x pipe?
Old Nov 29, 2006 | 04:09 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
h or an x pipe is an option. it just evens out the flow between the two pipes.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
