Desktop Dyno Exhaust Question
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Ok, I was playing around with this and noticed that when i put in that the exhaust is small tube headers with mufflers the HP and TQ readings are signifigantly lower then if i used small tube headers with open exhaust... Obviously the program cant be exact but the readings differ from about 386HP and 407ft Lbs of TQ to--- 411HP and 425ft Lbs, that is a huge difference, what is the auctual difference in real life about??
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Not sure if anyone can accurately give you an answer because every combination is different. Open exhaust means headers with tuned collectors.
So for a street car you can forget that. The figures are if the engine was on a dyno. Me, I just run the small tube headers with mufflers. When I run my combination through DynoSim I come up with 509hp and 485tq. We shall see as my motor is ready for the install.
LT1Formula
20
Nov 14, 2015 12:02 AM
