hedman longtube y pipe?
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
After I pass inspection with my new motor(when its installed) I hope to get new exaust.
On summit I found $180 hedman headers, and $3xx same headers just ceramic coated. Can i buy a y for theese or, do I have to have a shop fab one up for me? Would jet hot on the non ceramic coated headers be better then the ceramic coated?
what do you think of
hedman longtubes to dual 3 inch cut outs(electric eventually)-y pipe-high flow cat-banks catback.
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
The headers i think you are talking about are D-port. You would have to have a shop fab you a Y-pipe, hedman doesnt make one for longtubes. Overall i think that setup would sounds pretty good.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well i have the long tube hedmans, i bought a flowmaster y pipe 2 1/2 in single 3inch out, i had a shop fab the rest and installed summit cutouts in the process, i am happy with the system but i dont like to cap the cutouts.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Good luck finding a prefab LT Y-pipe!
Thats going to be a custom piece.
Bah heck, while your at it dont bother with a Y, build full duals!
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
If you can weld....or have a friend that can all you need to build a Y for the headman LT's is a 2 into 1 like the flowmaster.....four 45 Deg manderal bends (or a set os S bends)and a section of pipe.....you could get away with 4ft.but I'd go a head and get 8ft to make sure.Do a search as there are some good pic. on the board of some......as far as a cat back I'd just get the muffler back and have the I pipe made up as with the LT's your exhaust will be routed diff. and you'd wind up cutting about 2 1/2 feet off the cat back and tossing it($).If you find it hard to get a shop to do the work because of the emissions just tell them it is a track / show car and they "should" be O.K. doing it.
Good luck,
Mike
Good luck,
Mike
LT1Formula
Oct 8, 2015 08:34 PM
