2055HKR intall pics, comments
Old Mar 26, 2007 | 10:55 PM
joecautela's Avatar
I just got done today installing the headers, whew! I got photos and all kinds of stories if anyones interested
Old Mar 27, 2007 | 01:22 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: 2055HKR intall pics, comments
I haver a 87 IROC 5.7 and I am thinking about getting the Hooker 2055 as well. Please do tell about your install. What problems did you run in to?
Old Mar 27, 2007 | 03:22 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
want to know about these stories. have any problems? you get the y-pipe also?
Old Mar 27, 2007 | 03:27 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I have the same headers, install was less than 45 minutes.
Old Mar 27, 2007 | 06:46 PM
joecautela's Avatar
Well to start with:
-nelapse, 45 minutes to install headers? on what a new mtr on an engine stand?
-my car is an '88Iroc that was never apart for anything. It's only got 26K mi on it. I soaked all the manifold and Y pipe nuts overnite. I could not seperate the y pipe from the cat and had to sawzall it off. That left a ppipe slug in the cat that my local midas shop was able to get out for me. The y pipe nuts came loose ok with a little bit of a torch on 'em. All the manifold nuts and studs broke loose ok, it was just a pita to get at some of them. After pulling the air pump and swinging the dipstick out of the way I still had to yank the a/c compressor and diconnect the heater hose to the heater valve to get the header down the right side. Remember I'm using the a.i.r. setup so there's the extra tubing up top to clear. I decided to relocate the heater valve at this time and do the coolant bypass at the throttle housing too. I also installed new valve covers so the old ones had to come off too. On the left side the alternator had to be swung out of the way to get the cover off easily. I re-used a couple studs on #1 and #3 to re fit the air pump support bracket and the alternator and p/s pump brackets on the left side. I also changed over to the 3-wire heated O2 sensor. I'll take a break here and post some photos
Attached Thumbnails 2055HKR intall pics, comments-headers-009.jpg   2055HKR intall pics, comments-headers-010.jpg   2055HKR intall pics, comments-headers-013.jpg
Old Mar 27, 2007 | 06:54 PM
joecautela's Avatar
For some reason I had trouble posting this thread last nite and now there are 2 threads. Let the other one die
Old Mar 27, 2007 | 09:08 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Originally Posted by joecautela
Well to start with:
P&B blast the manifold bolts. cut the Y-Pipe, remove manifolds, install new headers, torque, install new Y-pipe, install stainless steel band clamp.
45 minutes.
I also have a lift if it makes you feel better.
Old Mar 28, 2007 | 02:01 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
i had to unbolt my pass motor mount and lift the motor a bit before my header fell into place
Old Mar 29, 2007 | 07:08 AM
joecautela's Avatar
I've heard that some had to do that but mine went in alright. I did have to swing the dipstick out of the way though. ck out the new location for the heater valve
Old Mar 29, 2007 | 10:34 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
LOL how did you get to the last bolt on the passenger side near the firewall? OMG...2 hours on that alone I was so pissed by the time I was finally able to get it tighened down my wife wouldn't come near me. I think every loose tool/item I could grab except the ones I needed found a place imbedded in the garage wall during that exercise in near futility.
I would get my tool on the bolt, only to have it slip off...or I wouldn't be able to tighten it and would have to reset the wrench...grr...oh that made me mad.
What tool did you use? I wound up using a bendex socket extention with a wobbly end and one of those pre-fabricated swivel 7/16 ends. I think that was the hardest bolt I could have ever gotten to. Now...I did leave the AC Accumulator in. Had I pulled that it might have gone a bit easier.
Old Mar 29, 2007 | 01:46 PM
BulliTooth's Avatar
Car: 1989 Formula
ya it was a pita but i just used a small wrench, im not a big guy (about 5/7) so that helped alot. i used locking bolts so i hope i never have to do that again.
Old Mar 29, 2007 | 06:11 PM
joecautela's Avatar
yeah that one in the back was bad. I used a tiny screwdriver to unfold the locking tabs and then got the 9/16 wrench on it w/ a 3/4 wrench as a reverse breaker. On my back under the car reaching up. I had the fronts up on ramps and the rear on jackstands so there was just enough room. Other than the 2 front studs that I reused the rest I used the stage 8 locker bolts. Doing the next to last one and the one behind #5 were the worst for me. But I'm ambidextrous so I used my sawzall box as a stepstool and laid on the mtr and used my left hand to snake down in there to start and tighten 'em LOL! This is one of those jobs that I used every physical position and quite a few different tools!...and..I used Delco Platinum plugs...a standard 5/8 socket w/ a 3/4 wrench was good in some spots while I used a cut down specialty socket w/ a 5/8 wrench on others. This photo is of tightening the bolt for the wire loom holders.
Old Mar 29, 2007 | 06:25 PM
gta31's Avatar
Car: 87 gta
Engine: l98
took mine to the local high preformance shop guy said they were easy and told 200 for the header's y pipe and new cat new wires new plugs so i let him go at it my bolts were in there good and he unbolted the motor in the end but it still tookk him about 10-12 hours worked out good for me bad for him the going rate on labor there is about 45 an hour
Old Mar 29, 2007 | 06:36 PM
joecautela's Avatar
sweeet! the going rate around here is $80-100/hr. I was doing the coolant bypass and I relocated the heater valve so I wanted to do it myself to make sure it was just what I wanted. The only thing I'm not too happy about is the gaskets. So I'm going to go back in soon and put a set of Mr. Gasket Copper gaskets in.
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
amcnellis
Sep 16, 2015 04:16 PM
gt4373
Sep 9, 2015 10:29 AM
