Header Wrap
Old Jul 1, 2007 | 03:23 PM
atomicskr's Avatar
Header Wrap
I got long tube headers on my l98 and man does that engine compartment get hot. Does header wrap actually work or do I need to look into getting coated headers ?
Old Jul 1, 2007 | 03:33 PM
ĦMR.AWESOME!'s Avatar
Car: '92 RS
Engine: 305 TBI
Re: Header Wrap
From what I've read, and I could be so wrong it's not funny, is that wrapping the headers will cause the internal temperatures to be crazy high and cause the metal on the headers to fail. Ceramic coating them will provide heat insulation and will protect the headers from corrosion a lot better than wrap would.
Old Jul 1, 2007 | 07:55 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Header Wrap
Wrapping headers will void the warranty. If ya read the install instuctions with most it is stated very strongly not to wrap them. Is the heat causing any problems? If its not causing a problem then dont worry about it----thats part of headers they pull heat out of the head and its gotta go somewhere.
Old Jul 1, 2007 | 08:37 PM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
Re: Header Wrap
I wrapped the headers on one of my past cars. Boy does it look good before you fire that engine up. After a while it just becomes a bigger mess. Like Mrbrooks said it's the hottest part of your exhaust. I would either deal with that or JETHOt coat them bad boys. But man ya Gotta love the sound of a set of long tubes.
Old Jul 1, 2007 | 08:40 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: Header Wrap
Don't wrap them...it just holds mositure up against the tubing and they'll rot out in two years. Trust me....I seen it a dozen times or more. Ceramic coat them.
Old Jul 2, 2007 | 06:46 AM
atomicskr's Avatar
Re: Header Wrap
Wow... thanks for all the responses. I guess I'll just have to bite the bullet and shell out for ceramic coating. Thanks for the advice everyone!
Old Jul 2, 2007 | 02:01 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: Header Wrap
If you drive in the rain, or park your car outside, dont wrap them. They will collect moisture.
They are good, if youre after performance and lowering temperatures. They are bad if you are after looks and making your engine bay pretty.
The hot exhaust (when hotter) flows quicker, which actually gives you power. As for rotting out, your headers will be that rusty in two years anyway.
Old Jul 2, 2007 | 03:31 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Header Wrap
It's actually the retained heat that destroys the metal.
Old Jul 24, 2007 | 06:38 AM
AUSSIROC's Avatar
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
Re: Header Wrap
Oh great. I wrapped my headers a couple of months ago, hopefully they last. I am super happy with 'em as they are shortys and don't really get wet. They make the engine bay much cooler though which is a good thing. Less chance of burns, which is also a good thing. Oh well, i have hacked up flowtech's to fit the rhd column, so by the time they rot out, i will prob upgrade anyways.
The headers look like a light grey under the wrap (no rust yet), but hopefully they will last.
Old Jul 27, 2007 | 08:47 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Re: Header Wrap
I used header wrap on a y-pipe on my old Chevy pickup cause it passed real close to the transmission pan. I ran it for 2 years through northeast winters and never had a problem. I plan on using it on the headers I am putting on my Formula next week.
Old Jul 27, 2007 | 09:23 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Header Wrap
I used to run Edelbrock Headers on the old engine. I did wrap them initially.. Then had the wrap removed and had them jet hotted.. Edelbrock invalidated my warranty because they didn't do it. But, of course they charged alot more. I just had my new Hooker 2210's Jethotted directly from them and it didn't have a warranty issue.
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
