hooker catback exhaust systems?
Old Aug 2, 2007 | 04:27 AM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Hooker makes just two different catbacks right? Which one flows better and sounds better?If anyone knows which one is the best can you give me a part number because hooker really doesnt seem to go into detail to explain the difference between the too. Need to order an exhaust asap and I want the hooker catback exhaust system. Thanks
Old Aug 2, 2007 | 11:18 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: hooker catback exhaust systems?
i believe (dont quote me) but the more expensive one has a test pipe with it while the other does not.......thats what i heard....
Old Aug 2, 2007 | 11:48 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I have not seen both either, but from what I understand, '89formula is right, they are the same, the more expensive one gives you the pipe to run in place of a cat converter. Otherwise identical.
TA
Old Aug 2, 2007 | 12:52 PM
Car: 91 Trans Am
I guess I will get the more exspensive one then. Thanks for your help.
Street Lethal
Apr 30, 2019 12:14 PM
billybob6110
Sep 24, 2016 09:50 AM
Slush92RS
Sep 2, 2015 08:56 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
makaveli09
Aug 12, 2015 09:07 PM
