dual cats
Old Aug 13, 2007 | 01:37 PM
greenes91gta's Avatar
Car: 1991 Trans Am GTA
Engine: L98 350
dual cats
Im new to this website so here goes... I have a 91 gta with stock dual cats. My cats are broke right at the back so I need to replace them for inspection. Does anyone have the stock dual cat system for sale or does anyone know where I can get a new one?
Old Aug 13, 2007 | 02:10 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: dual cats
you wanna save a crap load of $? Just go to summitracing.com. Buy 2 cats with the right inlet/outlet size, then go to a custom exhaust location and have them tossed in. I GARONTEE you will save over $100 EASY
Old Aug 13, 2007 | 04:12 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: dual cats
I believe Magnaflow has a direct replacement setup, designed to attach to stock manifolds.
Bill
Old Aug 13, 2007 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Two problems I see with that:
1) Most places won't install a cat that you brought in.
2) Letting a shop like that touch your car is sure to cost you at least $200. If the cats are universal type, it'll cost you even more.
Old Aug 13, 2007 | 05:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: dual cats
Welcome to TGO. A search is always to good thing. The following link was down a few threads:
https://www.thirdgen.org/forums/exha...dual-cats.html
JamesC
Old Aug 13, 2007 | 06:59 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: dual cats
Shop I go to does stuff like that for $20 cash. Probably $40 for dual cats.
Old Aug 13, 2007 | 11:50 PM
five7kid's Avatar
Cut out the old ones, adapt and weld in the new ones? Including A.I.R. tubes?
For anyone off the street?
Old Aug 14, 2007 | 06:46 AM
Engine: LS3
Re: dual cats
Same here. Lous Custom Exhaust around here in Boston. I got my old shorties welded to my pipes (dual cats), new Random Tech cats that I brought in, welded in, including air tubes and all, AND installed weld in SFC, including all new pipe to the cat back, rewelded all old connections and fixed my cat back matting connector leak.... Cost=$212.
For just putting in cats, maybe cost $40-60.
Old Aug 14, 2007 | 07:23 AM
JamesC's Avatar
Re: dual cats
Same here. For just putting in cats, maybe cost $40-60.
Sounds like an exceptionally good deal. Here in my rural community of 1800, cost would be considerably more.
JamesC
Old Aug 14, 2007 | 07:30 AM
Engine: LS3
Re: dual cats
If you live where it is hard to find a place to do work and you own a thirdgen. Invest in a Welding handbook, $12, and a MIG welder $200. Then for the rest of your life, you can do floor pans, Relocation brakets, 100% custom exhausts or patch up jobs, ANYTHING you want for free.
Thats what I did, and I DO have great deals like stated above around me. I just knew that I had rust on my floors and was going to want a bigger exhaust down the road. Best $ savings I could have ever done.
Old Aug 14, 2007 | 09:38 AM
Engine: L98 350
Re: dual cats
I have a mig welder but im not to swell at it... do you think a bad weld job would mess up how the exhaust will sound?
Old Aug 14, 2007 | 10:28 AM
Engine: LS3
Re: dual cats
NO.
Holes will, just weld them shut.
Listen go to my CD site through my sig. You will see the work I did with 100% ZERO auto training in any way, and I am in a 1 car garage that is tiiigghhtt. Very hard to work with. I am no expert by any means and I made a true dual setup, installed a 6 point roll bar and fixed 6 rust holes/problem areas I had. All with 0 training and the car has about 1600 miles on it now pushing aorund 400 HP and has 0 problems with my welds.
Go nuts, LEARN a new skill. You will be soooo happy that you did.
Old Aug 14, 2007 | 07:24 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Re: dual cats
Cutting out the olds ones is easy takes all of 2 minutes, nothing to really adapt as long as you get the same size, and same deal with the A.I.R.
No probably not for anyone off the street.. but I am not a regular where I get special pricing. They just tend to cater to "car guys". They spread pipe ends for me for nothing the first time I went there and that's all I needed.
Old Aug 14, 2007 | 07:42 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: dual cats
Why is this? I had Midas install my cat and catback. I had no cat when I brought the car in. I also brought the Catco cat with me.
Old Aug 15, 2007 | 07:02 AM
Engine: LS3
Re: dual cats
Some places won't due to warranty crap
Old Aug 15, 2007 | 10:33 AM
five7kid's Avatar
EPA crap. They are responsible for verifying the work they do does not degrade the emissions equipment. Some places may do it if they are reasonably confident the part you are bringing in is proper for the application. The local Midas here told me point blank they would not install a customer furnished cat. Another local independent shop told me they had to know the part was right for the application, or had to have the cat certified (not exactly sure how that is done, but the cost they quoted was about the same as a new cat).
Doing your own welding makes a lot of sense.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
