2 videos of my true dual exhaust
Old Sep 3, 2007 | 11:23 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Got two videos of the car here from thirdgenfest earlier this year. Done on a country road with no traffic for miles, it was checked before launching the car.
First is a burnout and the second is 1st/2nd gear launch and then it idling into the fest again.
SBC/headmann long tubes, headmann S-bend pipes, summit h-pipe, moroso spiralflow mufflers and 90' mandrel bends with it exiting in front of each rear tire for slightly quieter exhaust than dumps.
http://myspacetv.com/index.cfm?fusea...ideoid=9631100
http://myspacetv.com/index.cfm?fusea...ideoid=9635776
Old Sep 4, 2007 | 09:46 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Re: 2 videos of my true dual exhaust
Sweet man! The car sounds awesome!
Old Sep 4, 2007 | 04:43 PM
spidey1978's Avatar
Like it a lot.
I'm in the throws of trying to get a better 'note' from the exhaust. Do you have any suggestions ? A friend of mine works in an exhaust place and has the gear, we just need advice on 'how' and 'best practice'.
It seems as though under the car at the front of the drivers side floor pan there is a support that could prevent a pipe from running through there. I.e. this 'support' is not there on the passengers side.
Any pointers would be appreciated !
Old Sep 5, 2007 | 12:05 PM
xpndbl3's Avatar
Car: 1984 Z28
i basically laid out earlier the parts I used to get decent ground clearance, I'd order them and attempt to put it all together tucked up as much as possible.
Old Sep 6, 2007 | 06:35 AM
spidey1978's Avatar
Hi and thanks for your reply. fingers crossed all will work !
Old Sep 7, 2007 | 11:11 AM
xpndbl3's Avatar
Car: 1984 Z28
no problem, i have pics of the setup on my cardomain in my sig if you'd like to check them out if you have any issues.
Hotrodboba400
Dec 10, 2019 07:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
