Tx Emissions Failed, 3.1 V6 1991 could it be the EGR?
Old Oct 18, 2007 | 04:50 PM
emerrem's Avatar
HIGH SPEED EMISSIONS (25 mph)
Standar Current Reading
CO (%) 0.67 0.95
NOx (ppm) 848 1508
LOW SPEED EMISSIONS RESULTS (15mph)
HC (ppm) 124 157
CO(%) 0.69 1.36
NOx(ppm) 937 1352
O2 sensor?
egr valve?
I need help please!!!
emerrem@hotmail.com
Old Oct 18, 2007 | 05:00 PM
emerrem's Avatar
Re: Tx Emissions Failed, 3.1 V6 1991 could it be the EGR?
where the air pump hoses hook up to (the small one)?
Old Oct 23, 2007 | 11:05 AM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Run some seafoam throught the PCV valve thats on driver side valve and pour the other half in the gas tank drive the car through a tank of gas and take it back to retest and let us know what happens. Sounds like theres a lot of Carbon build up. Thats the black stuff that makes the emmisions higher.
Old Oct 27, 2007 | 12:21 PM
JRods Firebird's Avatar
Car: Different Rides but 1991 Firebird
Engine: V6 3.1 in Bird
Ive never tryed that. So remove the hose to the PCV and pour it into the drivers side valve cover or turn the hose upside down and pour it in that way. Would like to try this.
Old Oct 27, 2007 | 07:51 PM
Stephen's Avatar
Car: 87 GTA
You don't need a smog pump at all, to pass the test. Visually, you should fail, but it's more than likely they won't notice. Just leave the rump on, but pull the pulley. No empty bracket, no pulley missing a belt...
Just put on a new $50 cat. My cat was 1 year old, no smog pump, no AIR tube, and my #s were almost non-existent!
High Speed-2692rpm
HC 220-standard....4-my reading
CO% 1.20-standard ....0-my reading
Idle
HC 220-standard....16-my reading
CO% 1.20-standard ....0.01-my reading
92firebirdguy
Sep 1, 2016 07:53 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
89fast5oh
Sep 8, 2015 09:55 AM
