True dual question...
Old Jan 15, 2008 | 02:22 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Alright, this is my current exhaust setup... I have pacesetter headers that go to a 3 inch Y pipe, all the way over the rear axle, and into a flowmaster 80 series... I want my new exhaust to be this: Keep my headers, and from the headers back do a custom or aftermarket X pipe, preferably 3 inch and go into 2 super 44 flowmasters and then just dump them before the axle... I am aware that I am probably going to have to install it myself, so do yall have any tips or links to running my pipes? Or even if there is an aftermarket X pipe I can buy that will fit just fine under my car? One more thing, how do I go about mounting 2 mufflers before the axle?
Old Jan 15, 2008 | 02:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: True dual question...
there would be no real benefit to it with the shorties. i'd say get a set of longtubes
Old Jan 15, 2008 | 02:34 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I have Hedman long tubes, 2.5" pipes into an X pipe and dual Flowmaster 40's with turn downs. Sounds pretty good, but there isn't as much ground clearance as I would have liked.
Old Jan 15, 2008 | 02:50 PM
andrew91rs's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: auto
Just as another option you could always run the exisiting y pipe to a bullet muffler and dump it.
Old Jan 15, 2008 | 05:13 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
I know that I would probably benefit with longtubes, but for now... Could I make it work? Or would my best bet be to get some longtubes, then get the x pipe, then get the mufflers over a period of time, because I am not rich lol and then put it all together and put it on myself?
Old Jan 15, 2008 | 07:36 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
How much ground clearance do you have? I have shorty headers straight dual exhaust side exit pipes. And i have about 3 to 4inches of ground clearance.
Old Jan 16, 2008 | 03:45 PM
1985transmaro's Avatar
Car: 1985 Camaro-1986 Trans-Am Cross
Engine: 5.0L, Fresh From A Rebuild
Transmission: 700R4 Shift Kit
Axle/Gears: 3.03 Std.
be aware that any muffler before the axle will significantly lower the ground clearance of the car, so whatever you end up doing, get the lowest profile mufflers possible, i had mine ripped off in a few potholes, got pricey after a while. what motor do you have? with a 305 you wont notice any real difference between straight pipe-to-muffler and x-pipe-to-muffler. 350 and bigger there will be a small difference
Old Jan 16, 2008 | 05:38 PM
mw66nova's Avatar
Engine: 7.0L
where you gettin' that information? 350's R US? dude, scavenging is still the same regardless of engine size. a high winding 305 will like it better than a stock one, but it'll still effect engine output.
i've been posting these pics on every thread it seems. if you want something that's gonna be different, give you maximum ground clearance with longtubes, and have EXCELLENT scavenging. see, this big y-pipe junction i have works the same exact way an x-pipe does. it's all in the geometery and layout of the system to get it to work correctly. here's my car:
here you can see just how low my car sits and what kind of ground clearance i have:
Old Jan 16, 2008 | 06:15 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Does your dump before the axle or is it catback
Old Jan 16, 2008 | 07:02 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
For a cat back... don't you need a cat?
Old Jan 16, 2008 | 07:08 PM
mw66nova's Avatar
Engine: 7.0L
mine stops before the rearend.
Old Jan 19, 2008 | 04:02 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
isnt that pretty much in the same place as you had your true duals?
Old Jan 19, 2008 | 04:30 PM
mw66nova's Avatar
Engine: 7.0L
yes, but this has more clearance, cause i could tuck that muffler up into the tunnel and the y-junction acts just like an x-pipe. sound is similar to an x-pipe true dual setup too.
Old Jan 19, 2008 | 08:19 PM
Car: 92 Camaro
Axle/Gears: S60 373
i think i might be stealing the thread but was there any power loss or gain when u went from true duals to single 3.5?
Old Jan 23, 2008 | 04:40 PM
mw66nova's Avatar
Engine: 7.0L
actually, i think it makes more power because it's essentially an x-pipe instead of an h-piped dual setup.
mattcanty
Oct 12, 2015 11:08 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
