need some help im new at this
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
k guys i just got a 91 rs and i am doin a 350 swap and its all done just i need to know if i put long tube headers on it and run it out the side is the any clearence issues withany thing ,, with the long tubes on that is
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Long tubes will to some extent introduce clearance issues, both with routing and ground clearance.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: need some help im new at this
There is a webpage on TGO that someone has put together with ALL the long tube setups here on TGO and on other websites. I am not sure what the URL is but I know it helps alot, there are amny people who have actually made it easy to route long tubes for dual exhaust, whether it be stock location routing or straight back...
Im sure someone will chime in with the website....that or Ill try and find it for ya.
Search long tube pictures..maybe?
