Too restrictive of an exhaust?
Old Feb 23, 2008 | 03:37 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I currently have a 383 that puts out 470 horse and 450 ft lbs of torque at the motor. I currently have an edelbrock shorty's with an edelbrock cat back. Its not a true dual exhaust, but its a 3 inch pipe from the headers to the muffler which then splits into 2.5 inch dual after the muffler. Just want to know if this would be to restrictive. Thanks guys
Old Feb 23, 2008 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Was the engine dyno'd at 470 HP? If so, what exhaust was used to obtain that?
You're probably not making 470 HP with that exhaust, though.
Old Feb 23, 2008 | 04:57 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: To restrictive of an exhaust
It was on an engine dyno. With the shorty headers but not the rest.
Old Feb 23, 2008 | 05:56 PM
five7kid's Avatar
I assume it didn't got to a single 3" pipe, then.
That's pretty good power for shorties. Most people wouldn't believe they'd do it.
Old Feb 23, 2008 | 10:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Too restrictive of an exhaust?
Yes its restrictive. Edelbrock's 1 5/8" headers are not good, not to mention they're too small for a 383 anyway. Do a search on the Exhaust forum for Dyno Don Headers and send him a PM.
Old Feb 24, 2008 | 10:34 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
I use this car quite a bit on the street, and occasionally at the strip. So I was wondering what headers would fit without having ground clearance issues. I also wanted to make sure that the headers would just bolt right up like the shorties without having to take the engine out.
So would the 3 inch exhaust from the headers to the muffler, be to restrictive or will that would out ok. Thanks guys
Old Feb 24, 2008 | 11:54 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
My headers and y-pipe with your 3" cat back would be fine.
Most of us here use that setup.
Old Feb 24, 2008 | 07:11 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
What kind of headers do you have for our cars, and do they have any ground clearance issues, and can they be installed without taking the engine out. Thanks Dyno Don
Old Feb 24, 2008 | 11:27 PM
Dyno Don's Avatar
Look here & here:
https://www.thirdgen.org/forums/exha...-4-header.html
Copy and paste this one to the address bar.
https://www.thirdgen.org/forums/atta...eaders-w-o.jpg
Old Feb 25, 2008 | 11:03 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Dyno Don Are you shorty's 1 3/4 with a 3 inch collector, that would be something I am very interested in.
Old Feb 25, 2008 | 04:40 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
with a 383 is 1 3/4 with a 3 inch collector to big or to small
Old Feb 25, 2008 | 06:03 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Just right
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
BWilcox
Sep 20, 2015 12:19 PM
ericjon262
Sep 11, 2015 06:07 PM
