installin o2 on L/T's
Old Mar 31, 2008 | 02:57 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
hey guys.
i just got my hedman l/t's. i was wondering if anyone had any pics of where the o2 should go. i know it will have to be in the collector,but where is there room? on top of the collector,on the side,etc. i was thinking on the side facing the drivers door. any pics would be great.
thanks.
Old Mar 31, 2008 | 03:15 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: installin o2 on L/T's
Sorry, no pic's but, I installed a single heated 02 down stream after the y-pipe. The sensor now faces the drive shaft with the ground wire connected to the sub frame connector and connecting wires routed over the trans into the engine bay for the OE 02 connection, then the powering wire routed to the fuse panel inside the car.
Good luck!
Old Mar 31, 2008 | 05:18 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
you want it on the header collector for the "best" accuracy.
Old Apr 6, 2008 | 09:34 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
thanks guys.
