dual cats?????????
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
dual cats?????????
Hello,
I just bought a 1990 gta 5.7 350 v8 from someone in my town.
He told me that the car had dual cats on it. It has no cats on it now
and the tube that went into the cat is blocked off with a screw.
I have a few questions about this:
1. Will this throw a code in the vehicle?
2. Is there any way to verify the car actually had the dual cat setup?
3. Can I just use one cat (I want it to be emission legal)?
Any help/suggestions would be greatly appreciated!!!!
Thanks!!!!!!!!!!
craig
Thanks!!!!!!!!!!
craig
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: dual cats?????????
Hello,
Thanks!!!!!!!!!!
craig
Thanks!!!!!!!!!!
craig
2. All the '90 GTAs had dual cats.
3. To use one cat you'd have to somehow install it into the intermediate pipe very far from the motor. Light-off wouldn't occur until the engine was driven for lots of miles. Not the best for the life of the cat.
Catco sells a bolt-in setup w/dual cats. I got mine at Summit.
Transmission: 4L80E/4L80E
I don't believe that's a true statement.
I disagree. You could put a single cat in the same place the dual cats were. In fact, all factory cats are located in the same place relative to the engine on 3rd gens; so, whether single or dual, they are going to "light off" the same.
You would need a "Y" to join the two pipes to the inlet of the single cat, that's all.
Engine: LB9 225HP
Axle/Gears: 3:45BW
Oops! 673 of 884 1990 GTA's had the N10 Dual Exhaust.
OP should look at his build codes (in the center console) Look for N10 code
I disagree. You could put a single cat in the same place the dual cats were. In fact, all factory cats are located in the same place relative to the engine on 3rd gens; so, whether single or dual, the are going to "light off" the same.
You would need a "Y" to join the two pipes to the inlet of the single cat, that's all. Yeah, but it seems like you'd be spending bux on labor just to save sixty bux on a Catcon
I'd just get the Catco bolt-in.
Depends upon what was done to remove the cats.
scorpion, what does your exhaust look like where the two sides come together? Or, to put it a different way, where do the two banks come together? If two pipes were put in where the cats were, then it might be simplest to just put two cats back in.
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
the dual cats will flow better than one, theres no y pipe each cat is for each manifold then i would y it and run 3" all the way back after that
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
There is one cat bolted right onto each manifold - correct.... but there is still a Y-pipe. The Y-pipe is AFTER the cat converters on a dual-cat setup. Its not a real dual exhaust setup like the RPO description might lead one to beleive. Its set up similarly to the LT1 4thgens, thought not identical.
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Any one have a pic of this dual cat I might be considering it for my '86
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
https://www.thirdgen.org/forums/exha...k-systems.html
Look at the last post in that thread, I posted pics I took of my dual-cat setup when it was stock, when I first bought the car.
Early in my 3rd gen days, I had a bud who kept telling me to go dual cat. "It's worth 10 HP," he kept saying. Well, true for factory cats, but anything you buy these days will be high-flow, so the advantage is reduced with dual 2-1/4" vs. single 3". Dual 2-1/2" might be slightly better than single 3", but that isn't the factory dual cat size.
Car: 1991 Chevy camaro z28
Engine: 5.7L 350
MY 91 Z has the factory dual. The individual banks ran into two cats under the passenger floorboard, then y'd after the cats to a single pipe running to the muffler, where it then split into to two pipes back to the tips. I've only been able to put OEM replacements in, but I think Random Technologies makes some high flows for f-bodies. Might check Year One.
No reason to "settle" for OEM.
There have been reports that OEM replacement is even high flow now.
More of an "F" pipe. . .
Engine: 5.7L 350
By "OEM", I meant GM parts, and I assumed that's what you meant. However, rarely if ever are GM parts less expensive than aftermarket.
And, aftermarket, even if "OEM fit", will be high-flow.
The factory dumped them into the same size cat-back as they did single cat, so the difference then was the design of the cat bed. Even if your dual cats are 2-1/2", you're probably dumping them into a single 3" cat-back as well.
But, who is going to volunteer to do a back-to-back dyno or track comparison????
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
2 cats dumping into one three inch pipe is a waste of money. True duals front to back would be of some benefit on a high horsepower motor. A single cat three inch exhaust is more than adequate for a bolt on third gen.
Car: 1990 gta
That's good news. I checked for a dual cats system and it was $300.
So I will just go with the a single cat.
No, I believe the dual cat cars put out more HP than the single cat cars. But, you're doing it different than they did; with products available to you that either weren't available during production, or that the factory chose not to use due to cost etc. Which goes back to my previous cat bed comment, and why dual 2-1/4" would perform better than single 2-3/4" (aka, 3"), even when followed by 2-3/4" exhaust.
Dual high-flow 2-1/2" into 3.5" cat-back will certainly support more power than single 3" high flow into 3" cat-back.
We really are in an apples-&-oranges discussion here.
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I have a dual cat setup but I cut the cats out and had straight pipe welded in place with the y pipe in front going to a 3in catback. It actually worked out pretty good. scorpion I still have the two high flow cats from catco so if you want to save some money and go with a dual setup I will give them to you for free, you just have to pay shipping. They are in good shape still with only around 4,000 miles on them.
POOR FLOWING. Today you can have one 3 incher flow better than two of the older designs did. The cars were identical otherwise.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I can't believe this. This thread and others with the posts that one catalytic converter flows just as well as the two catalytic converter system. Dream on guys.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
you did not read it right. one high flow is better than two OEM. But i would think two high flows would be better than one high flow and it is. Remember the old 350 H.O. conversion? well dual cat conversion was part of it.
However, the factory single cat system is poorly designed, especially on the 305 cars. Its more like a T-pipe than a y-pipe. If you have a redesigned y-pipe that is truely a Y, into a 3" cat, that will flow a hell of a lot better than factory. Whether its better than an upgrade dual-cat setup, I have no idea for sure. But I'm still sticking to my theory that 4 cylinders flowing into 2.5" is better than 8 cylinders flowing into 3". With a single cat system, you're doubling the number of cylinders but only increasing the pipe size 20%. (half an inch is 20% of 2.5 inches)
Transmission: 4L60
okay simple version two high flow cats are the best setup. If you can only afford so much then get one high flow not two OEM cats.
LT1Formula
Oct 8, 2015 08:34 PM
