what exhaust gaskets do you run?
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
well for a while now my car has been leaking exhaust...around both the heads and the collectors. I recently did a head swap and it wasnt leaking and it sounded the best it has in a while...then after a while the bolts loosened up and it started leaking again...
i'm using the cheaper fel pro gaskets on both parts
what do you guys use? i am having no luck with these
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: what exhaust gaskets do you run?
I'm using Earl's header gaskets that I bought through Summit Racing. No problems at all.
Car: 1986 Trans am
Engine: 383ci
Axle/Gears: 2.77/3.45 ready to go in
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I use a copper gasket. Works good. To stop exhaust leaks you'll need to buy some quality exhaust gaskets
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
