I-Pipe not Mandrel Bent! (Dynomax/Summitracing)
Old May 4, 2008 | 06:20 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I was (just) told that its normal for the I-pipe section going over the axel to be 'crushed in' from the factory for clearance issues, however after installing the pipe, it seems as though theres enough room so that they didn't have to crush the pipe....whats the story with this? I wanted a "FULL" mandrel bent exhaust system on my car and i feel cheated (after spending good money)...I've never heard anyone else speak of this...(I orderd the 2 I-Pipe sections from Summitracing, 3" Dynomax pipes) Can a "regular, non-crushed" pipe be ordered?
Old May 4, 2008 | 06:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: I-Pipe not Mandrel Bent! (Dynomax/Summitracing)
my flowmaster is all mandrel bent
Old May 4, 2008 | 06:51 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'm pretty sure there are some catbacks that do the same thing to the pipe. I could have swore the hooker catback has it also. I'm not totally sure.
I purchased the same Dynomax 3" I-pipe from Summit. It's all Mandrel bent, it just has a "dent" on the section that goes over the axle.
[Edit]
Found a thread: https://www.thirdgen.org/forums/exha...ht=hooker+dent
Old May 4, 2008 | 06:56 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
It is i believe for the travel if the handers when it is bouncing around so you dont hear a klank noise from swaying a bit.
Old May 4, 2008 | 08:49 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I believe it's standard fair for most 3"+ catbacks... I've seen it on the Flowmaster american thunder and Hooker catbacks.
Old May 5, 2008 | 09:45 AM
Car: 1988 SC Camaro
Engine: 305 TBI
The I-pipe that I bought came in (2) sections...But I can't seem to find where I can buy the same rear section that doesn't have that stamp in it...I looked under my car and it looks as if there's enought clearance so that the stamp isn't necessary....I'm going to try and see if Summit sells a 'regular' rear section...
Old May 5, 2008 | 10:34 AM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
It's usually referred to as the S-pipe... the I-pipe is just the long section.
Old May 5, 2008 | 12:37 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
My stock 2.25" facotry exhaust has that same indentation there. I think it is for the panhard bar.
And if you are looking under your car, you would have to have the suspension completely loaded (i.e. ratchet the rear end to the body somehow) before you could possibly tell where clearence is needed or not.
If the dent is factory made - just leave it. Not gonna hurt flow or anything lol. The people that design these things are not stupid - they get paid to figure out where this stuff is needed.
Old May 5, 2008 | 12:49 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Yup, that's exactly where the indent is on my exhaust... right over the panhard bar.
Old May 5, 2008 | 01:59 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Alright, I guess I'll just leave it alone then...its already in place...I just never heard of that before now...I looked at some pictures of the 3" Flowmaster Kit on Flowmastermufflers.com and there's no indentation(stamp) on their I-Pipe as seen in their pictures...Maybe there is a cat-back that doesn't have it...something to keep in mind for next time...
Old May 5, 2008 | 05:51 PM
Engine: LO3
Well if you look on your stock pipe, it will probaly be there albeit bigger maybe.
Old May 6, 2008 | 08:39 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I've owned, and installed myself, both Flowmaster American Thunder, and Magnaflow 3" exhuasts and they are a full 3" from cat to muffler with no dent or anything going over the axle. Neither one hits the suspension.
dbrochard
Oct 3, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
RedLeader289
Sep 23, 2015 06:50 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
