Clogged Cat?
Old May 15, 2008 | 01:43 PM
84 maro's Avatar
Car: 84 Camaro Sports Coupe
Engine: Carb'd 5.7L 350 W/ Funct. SS Hood
Axle/Gears: Stock for now
Clogged Cat?
my car started making a raspy noice in the exhaust when at a high rpm and felt like it had no power, recently the cat had a rattle in it as if something was loose, when i would floor it and shift a little bit of smoke came out, could it be clogged?
Old May 15, 2008 | 01:47 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Re: Clogged Cat?
Yup That might be a good indication its toast. put a straight pipe in there if your state allows it. or replace witha new cat.
Old May 15, 2008 | 01:52 PM
84 maro's Avatar
Re: Clogged Cat?
is there no emission problem with a straight pipe on these cars? and would it be better than a high flow cat? im sure thats a dumb question but im still learning alot
Old May 15, 2008 | 01:54 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Clogged Cat?
You won't pass inspection without a cat, and it is technically illegal to run without one. But if you have a state with relaxed laws and no inspections, it is very unlikely to get noticed.
Old May 15, 2008 | 01:57 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Clogged Cat?
if u got emissions than u need one and since u need a new just go with a high flow cat
Old May 15, 2008 | 01:58 PM
84 maro's Avatar
Re: Clogged Cat?
oklahoma kicked the inspection stickers, so the straight pipe would be better than a high flow cat?
Old May 15, 2008 | 02:00 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Clogged Cat?
if no inspection just go no cat better sound less restriction
84 maro's Avatar
Re: Clogged Cat?
im just now getting into my exhaust and im not positive if my car would have an issue with the emissions do you know? it an 84 with 350 crate swap all old school still
Old May 15, 2008 | 02:06 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Clogged Cat?
well even if ur area had emissions tests i not 100% sure but when a car is 25 years old it dosent need to be tested eny more and if ur cars a 84 then its 24 years old so u maybe ok takin the cat off now
Old May 15, 2008 | 02:10 PM
84 maro's Avatar
Re: Clogged Cat?
just have a piece of pipe put in place of it? or would that be a y-pipe? sorry im asking reall dumb questions but thanks for the help
Old May 15, 2008 | 09:51 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: Clogged Cat?
No, a y-pipe is what connects the manifolds/headers to the cat. So yes, just put a piece of pipe in place of it. But if you're having a shop do it, they most likely won't because it's not legal.
Old May 16, 2008 | 02:58 PM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
Re: Clogged Cat?
It's illegal to remove your cat. Even if you don't have emissions checks, you can still get caught. I've had 2 cops get down on their hands and knees and check to see if I had a cat.
Eventually they will change the laws to California style emission checks for every state and you will get caught. Just go buy a high flow cat. They're only like $80 and barely any restriction at all. I'm gonna get one this summer when I put new exhaust on my car.
Old May 16, 2008 | 03:23 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Re: Clogged Cat?
i dont have a cat on my car. i didnt do it my uncle (who works for the township) made a stright pipe for my exhaust when he put my exhaust on hes one of the guys who puts the computer stuff and thiongs into cop cars i cant wait to get pulled over and a cop checks for a cat and dsoent see one and see what he says when i tell him who did that gonna be a fun conversation. If your cat is clogged just gut it an put it back on then it looks like you have one.
Old May 16, 2008 | 10:30 PM
84 maro's Avatar
Re: Clogged Cat?
i work for a body shop so i got the hook up they yanked it and put a shiny new pipe in lol but thanks for the info,but he said my cat was all clear so i dont know why i had such a loss in power and the puff of smoke when i shifted but its all gone anyways
Old May 16, 2008 | 10:42 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Clogged Cat?
Yep, mine was making noise, or so I thought. I unbolted the Y-pipe, looked inside and there was NOTHING in it...Looked like everything had been cooked out long ago. I hooked it back up without a problem. I live in California in an "Enhanced" smog check area, meaning they hook you up and run your car while under load, with the wheels rolling. Anyway, I passed smog no problem.
Old May 17, 2008 | 01:17 AM
Alaska Hwy 1Le's Avatar
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
Re: Clogged Cat?
My buddy bought an 86 TPI Z28 with an automatic a few years ago for $800. The car was in very nice shape almost mint. The sellor thought the tranny was toast thus the cheap price. Turned out the Cat was plugged solid. He replaced it with a strait pipe and it ran fine. I was so jealous of his lucky find. I took mine out years ago. I live in the middle of nowhere so no one ever inspects for emmissions equip.
Old May 19, 2008 | 10:41 AM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Re: Clogged Cat?
I am in the same boat right now. My mechanic said the tranny was shot and when I brought to a guy familiar with thirdgens he stated it was only a clogged cat.
Did not fix yet (waiting on parts)
Old May 20, 2008 | 01:07 AM
84 maro's Avatar
Re: Clogged Cat?
i still have a bogging problem in second gear about mid way and through the top end of 2nd removing my cat gave me a noticeable increase in HP and seemed to have helped it a lil bit, also after shifting to second sometimes i can feel the front end drop as though it cuts out but picks back up good till that mid point, does anyone have an idea? im thinking either carb issue or i might have a clogged EGR valve and just need to completely remove emmisions, any advice would be appreciated
Old May 20, 2008 | 01:15 AM
Kevin84Z28's Avatar
Re: Clogged Cat?
I'd post that question in a new thread.
Old May 20, 2008 | 02:15 AM
Engine: 350 ZZ6
Re: Clogged Cat?
How does it run in the other gears? Is it only second?
Old May 20, 2008 | 02:19 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Clogged Cat?
When the cat in my truck was clogged, it had no power at all, felt like I was towing a bus or something. Top speed was maybe 35mph, and the engine wouldn't really rev past around 2500 RPM.
Old May 20, 2008 | 01:56 PM
84 maro's Avatar
Re: Clogged Cat?
yes the very beginning of second it studders a lil bit but then it picks up and goes till about 50 then starts cuttin out unless i reduce the throttle a bit and if i do that it takes off like its floored again
Old May 23, 2008 | 09:07 PM
Engine: 350 ZZ6
Re: Clogged Cat?
First thing, put a new fuel filter on it. If it's never been changed theres a good chance that it is clogged. Old clogged fuel filters can produce symptoms like yours. Will run ok when idle/light throttle but starve when the hammer is down. When you let off the throttle and it "takes off again" could be the crap in the filter loosening under lower fuel pressure. Floor it and the high pressure tightens the crud up against inside the filter. Check for a kinked fuel line also.
Old May 24, 2008 | 08:13 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: Clogged Cat?
f*ck that BS,Just pay the guy who does your inspection $20 extra, you'll pass, You dont have to run a cat
Old May 24, 2008 | 09:38 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Clogged Cat?
From someone atop of the gene pool....
Old May 24, 2008 | 10:04 AM
Car: '87 Iroc-Z
Re: Clogged Cat?
no from someone who livesoutside the box you goody twoshoes
who cares,people pay to have the car illlegaly pass inspections everyday
Old May 24, 2008 | 10:15 AM
84 maro's Avatar
Re: Clogged Cat?
Okay will do, im pretty sure its not kinked i still have the metal fuel lines running up from the pump to the carb so i doubt it is but cant hurt to check
Old May 24, 2008 | 10:29 AM
Car: '87 Iroc-Z
Re: Clogged Cat?
sorry for almost stealing your thread
Old May 25, 2008 | 03:04 AM
84 maro's Avatar
Re: Clogged Cat?
lol i noticed but its okay just tryin to get rid of this f in bog my car would be much faster cuz the times it doesn't bog its a blast to drive, it seems to not mess up cold but once its really warm its not good anymore
Old May 25, 2008 | 03:25 AM
Engine: 350 ZZ6
Re: Clogged Cat?
Iam by no means an expert, especially on carbs but the cold/hot thing would make me suspect carb problems. Some kind of vapour lock or the floats are sticking down.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
