Exhaust Termination Boxes
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm making this post for those doing research on the subject.
The idea for the exhaust termination box is for the exhaust collector to act like it is exiting into atmosphere. If done correctly the exhaust will "think" there is no exhaust system or muffler after the termination box. It is part of exhaust wave tuning. It can be a substantial horsepower gain.
You need the proper size header primary pipes, a good merge collector, the proper diameter collector pipe and the proper length for the collector pipe. This will all dump into the termination box. The good thing is this will work quite well with properly built shorty headers. You don't need long tube headers.
There are a couple of things I have found out in my research. Some of the information is from Jon Bauer(Bret's father) who built termination boxes for the Engine Masters Challenge. One problem will be heat under the car. One solution is to have the system sprayed with a thermal barrier such as used on headers. I will be going that route. Another problem is oil canning. You do not want to use a flat sided box. It will eventually tear itself apart with the exhaust pulses and have a "tinny sound". If you are using a larger diameter pipe I see no problem. Myself I will be using oval tubing.
David Vizard has covered the subject quite well in his exhaust science article for further information.
Car: 1989 GTA
Engine: 369 TPI
Re: Exhaust Termination Boxes
I have acquired the material for my first termination box. Here are some pictures. I will be using this thread to show the progress. By the way this piece is around 415 cubic inches.
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Isnt this concept the same as a single chamber muffler? Forgive my ignorance, but...???
An empty muffler case has been used as well as fabricated enclosures. These appeear to offer a greater difference in cross section ( I'm not refering to the actual box volume ) that can be provided with any oval tubing I've come across. It's difficult to tell from the posted pics. What size pipe is that?
Do your contacts agree with the idea? Personally I think it's our best shot at getting this to work with our limited work space. I'll be watching with interest.
Car: 1989 GTA
Engine: 369 TPI
"Isn't this concept the same as a single chamber muffler?"
Possibly depending on how the muffler is designed and the cubic inches. Also it would have to be in the proper location to generate the wave tuning effect.
Skinny z. The tubing is 4"x7" and 16 gage. I don't think substantial change in size has to be very much. Just look at the one Vizard made up for the Corvette. The size of oval tubing for the passenger side exhaust will be 3.25"x6" and 16 gage.
My collector pipe diameter is 2.75" and corresponds to size recommended by PipeMax.
Car: 1989 GTA
Engine: 369 TPI
Hehehe. I just finished the Super Ram modification for someone else. Now that I'm back to working on my car the Super Cold Air Intake is next on the plate.
No restrictions allowed.
My tubular K-member was to have shipped today. Should have it by next Friday. Next up is the new transmission support with the driveshaft loop. This will allow room for the exhaust pipe to pass through the area and allow for the termination box.
No restrictions allowed. My tubular K-member was to have shipped today. Should have it by next Friday. Next up is the new transmission support with the driveshaft loop. This will allow room for the exhaust pipe to pass through the area and allow for the termination box.
Cold Air Intake!
Should we start a new thread for that one?
I've been trying to build an effective CIA for a carbed application for a while.
Short of a cowl hood there dosen't seem to be a lot of options.
Car: 1989 GTA
Engine: 369 TPI
The CAI is for my TPI and I already have a thread on it. Here is the link with an updated picture from this evening.
https://www.thirdgen.org/forums/tpi/...-cold-air.html
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wow good deal, glad to see your startin this. I havent gotten around to getting cutouts. I bought a nitrous kit instead, oh and a roll bar but that isnt getting installed probly for another month
I'll try to get cutouts in to do some testing on collector length to show what there is to gain when you design the system right.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
can someone post up the formula for coming up with proper pipe size and location? the new motor will likely benefit from a larger diameter primary (ie, i'm running hedman lt's, would like to upgrade to the hookers) and when i do i'd like to reconsider the exhaust system once again. i'm currently running a single 3.5" exhaust and i'm wondering if i'll benefit from either a larger 4" or from going back to a dual 2.5" system with an x-pipe.
Car: 1989 GTA
Engine: 369 TPI
mw66nova your best bet is to get a copy of Larry Meaux's program called PipeMax. You can find it at www.maxracesoftware.com
That way you can plug in your motors numbers and your goals. The program will tell what size pipes are the best. Also does the intake.
Car: 1989 GTA
Engine: 369 TPI
A little update and with good news. The tubular K-member arrived from RaceCraft today so I could take some measurements. Looks like I will have lots of room for the drivers side exhaust termination box. The passenger side termination box will go on the passenger side where the factory exhaust runs. Here are some pictures showing the placement of the termination box. I will have a serparate thread on the RaceCraft K-member. Here are the pictures.
Car: 89 Iroc-z
Transmission: TH400
it will be interesting to see how you lay all that out
i still havent gotten around to doing cutouts yet... my bad guys. that be some good data to get before and after cutouts with pipemax determined collector length. i got that nitrous kit and the power is awesome, i dont want to race on motor anymore
Car: 89 Iroc-z
Transmission: TH400
lol yes. I hope to get it on the dyno soon if i could get a weekend date somewhere. Maybe if i could get the cutouts on then i can do a motor run, cutout motor run, then do the nitrous tuning
I do think these termination boxes will work i just dont have much room to do it
Car: 1989 GTA
Engine: 369 TPI
"i just dont have much room to do it"
That is the problem and I had given up. But I saw an installation with a tubular k-member and the light bulb went on. That and a custom oil pan it will all fit. It looks like I can get in nine times the cubic inches of one cylinder.
Car: 89 Iroc-z
Transmission: TH400
my headers dump before the crossmember by like 18 inches.
If i do the boxes i'll have to go to true duals, with 4inch tubes as my boxes, or i may beable to make my own using plate sheet steel.
But thatts just more work
4inch may work, i wont beable to fit 5 inch... so thats out. unless i ovalize it.. but that would be difficult.
I think longtube cars need to do duals with boxes because the joint volume will have to feed twice the engine displacement and thats alot. on my setup, you could make a custom shaped box down the driveshaft tunnel but its tight in there and clearance will be lost. My clearance sucks as is
But thatts just more work4inch may work, i wont beable to fit 5 inch... so thats out. unless i ovalize it.. but that would be difficult.
Car: 1989 GTA
Engine: 369 TPI
"Do you think there would be sufficient space with LT headers and the tubular k-member?"
...and the exhaust termination box? I would have to say no. Maybe with mid length headers which would not be all bad. I think PipeMax says something around 13.5 inch primary pipes for my setup or 15" for a setup like Orr's.
With the tubular k-member and custom oil pan I think a custom set of long tube headers would fit just fine with plenty of ground clearance.
Car: 89 Iroc-z
Transmission: TH400
Yeah thats the benefit, a k member and oil pan will make it easier to have nice longtubes that fit good and have better primary lengths..more equalized than most headers that fit these cars
shorties with the ypipe crossover makes it possible to put a box there
Car: 1989 GTA
Engine: 369 TPI
Just a little update. My Canton custom oil pan came in today. This will allow me to run the drivers side termination box under the oil pan. Here are some pictures of the oil pan.
Car: 1989 GTA
Engine: 369 TPI
Update on the exhaust termination box. Here is the drivers side termination box with the exhaust exit now welded in place. The exit pipe will run along the passenger side of the transmission. The exit pipe is a piece of taper going from 3.5" to 2.75". Here is a picture.
Edit: The picture shown is how it would be installed if you were sitting in the drivers seat and looking forward and a little to your right. The header collector will enter from the left side of the picture. The termination box will fit under the oil pan going South North in the picture.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
1989GTATransAm
I think that PipeMax program was the most expensive piece of software you've ever used. We'll still keep an eye on what sort of results this brings.
TA
TA
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
A termination box to bring some of the noise back under control might be just the way to go, keep us posted.
Car: 1989 GTA
Engine: 369 TPI
"I think that PipeMax program was the most expensive piece of software you've ever used."
Hahaha. It is the guiding light to the end of the horsepower tunnel and my wallet.
Car: 1989 GTA
Engine: 369 TPI
Here are some progress pictures of the transmission support I'm making up to allow the exhaust tube to pass by without dragging on the ground. I also will remove the torque arm mount off the transmission to the support bracket. It will also have a driveshaft loop mounted on it.
Difficult to tell from the single photo. Will the boxes be installed parallel to the centreline of the car or across it? ( like an OEM muffler ).
It's great to see some progress. Seems we've been discussing it forever.
Keep at it and good luck.
Regarding the trans crossmember.
Do you think the aluminum has the fatigue resistance to stand up to what you'll put it through? I've seen less robust pieces than yours ( made of steel however ) that can't handle the constant compression, torsion and tension. Particularly the torque arm support.
Car: 1989 GTA
Engine: 369 TPI
Across it under the oil pan. I edited my post for more clarification
The transmission support cross member is far from complete. There are many gussets yet to be installed for increased strength and that includes the torque arm mount.
I wasn't commenting so much on the construction (and it's an excellent looking piece) but rather the phyisical limitations of aluminum in general.
I'm sure you've planned for all the abuse you'll give it.
Looking forward to the finished product.
Car: 89 Iroc-z
Transmission: TH400
applaud you for your efforts. Your actually going thru the steps thats great to see. I've talked about this but never got around to even testing cutouts for proper length exhaust let alone planning termination boxes
oh well i'll get around to it someday
Car: 1989 GTA
Engine: 369 TPI
Thanks guys. We will find out on the aluminum. Gary Stein who does the welding has a fabrication shop where he designs and makes, roll cages, car frames, motor mounts and you name it for car racing. Anyways he thinks it will work once we get all the gusset/bracing supports in place. It should be pretty stout once it is all done.
atc3434 wrote: "I am one step further than the termination box - I just have the termination - right after the Y pipe."
Yep, providing the distances are correct by the open pipe you did what I'm trying to duplicate with the termination boxes.
Last edited by 1989GTATransAm; Oct 30, 2008 at 06:37 PM. Reason: Automerged Doublepost
Axle/Gears: 9bolt
A similar effect can be had with an "x" pipe, as the pulse nature of exhaust will make it appear to the exhaust that the single pipe "doubles" in area at the X. Placement of the x pipe on a dual system is critical to power, but the only way to know where it works best on a given system is to keep moving it and and dyno testing, and I don't know anyone who is really up for that.
Looking forward to learning something, keep up the good work!
TA
TA
Car: 1989 GTA
Engine: 369 TPI
Probably should start another thread on this. Most of you know I'm upgrading to the 4L60E transmission. I have bought the TCI stand alone controller. Here is a picture of it mounted on the base I made up and put a couple of switches on it.
One switch is "dyno mode" so it will automatically lock up the torque converter at any speed you put in the program. The A/B switch is for two different programs that control the transmission. The A mode will be for the street and the B mode will be for the track.
This is also interesting. I've cooked a couple of 700R4's ( my own doing I'm sure ) and I've been checking out the 4L60E.
I'll subscribe to any new thread you start on this one.
PS. You have way too much time on your hands!
Car: 1989 GTA
Engine: 369 TPI
I bought one of Dana's kits at Pro Built Transmission. I told him I wanted to spin the motor to the 7000rpm range and the horsepower would not exceed 600 for a little safety factor. So we shall see.
Car: 1989 GTA
Engine: 369 TPI
Yes it does. Just check the software box that you have a 4L80E. In fact there are quite a few extras such as manuel shifting.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
What improvements do you expect from the 4L60E, as compared to the 4L60/700r4?
Bill
Bill
Car: 89 Iroc-z
Transmission: TH400
same tranny but with adjustable shift points via electronics. you can precisely dial in the shifts much easier than playing with governor weights/springs. Much more accurate so you should beable to get the most efficent 1/4 mile times out of it.
Car: 1989 GTA
Engine: 369 TPI
Exactly. I could have spent the money to build up my 700R4 to handle the power and rpm and have the same problems with a shift point as I do now.
Now with the 4L60E all I have to do is stab the throttle and go with the shifts points already dialed. Makes it so much easier for someone with limited driving skills like me.
Car: 1989 GTA
Engine: 369 TPI
Yes, I should have some pictures maybe sometime next week. This will be the passenger side one. It will be about 1/2 done. I will have to wait for the new motor to be installed the car to totally finish it off.
I believe I can finish off the one that goes under the oil pan without having to have the motor in the car. I'm waiting on the short block to be finished so I can complete it.
Car: 1989 GTA
Engine: 369 TPI
I have the passenger side exhaust termination box back from the welder. I have taken 3 pictures to post showing the progress so far. The box goes under the passenger seat where the factory exhaust is routed.
The 45 degree outlet is where the catalytic converter will go. The outlet is tapered from 3.5" to 2.75 inch. The notch is to clear the frame support member at that location. I will have to have the motor in the car to finalize the other end of it. I have tried to have no flat surfaces outside that small portion on the oval itself. Here are the pictures.
Car: 1989 GTA
Engine: 369 TPI
Right now about 430 cubic inches. It might go up some if I have to add an extension off to the side to meet the collector pipe. The length of the collector pipe is the most important length when tunning the exhaust. So that cannot change.
