what to get suggestions
Old Oct 12, 2008 | 03:34 PM
Fmaro's Avatar
Car: 1987 Camaro T-top
Engine: current 305(LG4) awating 400ci sbc
Transmission: Current 700r4 awating T-56
Axle/Gears: stock LSD 3.23s?
Ok so i just got a 87 camaro 305, and the people before be didnt take care of it,...everything is plugged,, filter, carb and CATs
anyways im cutting out the cats on wed and i want to know what to replace them with or what to do to make is sound good/ pretty loud
im just going to run it without the CATs until i get something for it
Old Oct 12, 2008 | 07:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: what to get suggestions
Your two best options are to either cut out the cat section (cut it, you'll never get those bolts off if its the bolt on type) and have a new piece of pipe welded in, or cut off the cat, bash the honeycomb stuff inside out, and put it back on. Either method will give you effectively a straight pipe, but gutting the cat is probably the easiest and cheapest.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
