True duals
Old Oct 19, 2008 | 09:52 PM
pgh1992's Avatar
Car: '92 Camaro
True duals
Is there any way to run true duals, I’ve been to a few muffler shops and they said it couldn’t be done, or that the price to do it wasn’t worth the results. I have a cat back system on mine now, sounds good, just looking for more.
Old Oct 19, 2008 | 11:03 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: True duals
true duals sound awsome imo but unless you can get them custom fabbed in the stock location to tuck up high and if you have a motor to benifit from them i wouldnt do it. i had them on both my thirdgens and i loved the sound but it was loud and i scraped on everything since i wasnt able to get them tucked the way i want. if you need the extra flow go with a single 3-4in exhaust im going with a single 3.5 with a cutout then 3in into a stock ls1 muffler.
Old Oct 20, 2008 | 01:21 AM
pgh1992's Avatar
Car: '92 Camaro
Re: True duals
it has the 305 do you think i would notice any power or sound gains?
Old Oct 20, 2008 | 01:46 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: True duals
2" tubing up to 100 hp per pipe
2.25" tubing up to 160 hp per pipe
2.5" tubing up to 200 hp per pipe
3" tubing up to 300 hp per pipe
92 RS camaro = 170hp stock
92 Z28 camaro = 205hp stock
a single 3 inch catback is more than enough for you car.
Old Oct 28, 2008 | 01:09 AM
Screamin86's Avatar
Re: True duals
Old Oct 28, 2008 | 03:22 AM
streetassasin's Avatar
Car: 2001 SS
Engine: bolt on LS1
Re: True duals
How did you come up with this? A couple guys I know make more than 300 rwhp with a single 3" exhaust. One did 415 rwhp throught a borla cat back and the other did 575rwhp through a hooker catback, both are single 3".. I have never had my car on a dyno but am making an estimated 415-430rwhp on a 100 shot through a single 3"
Old Oct 28, 2008 | 11:23 AM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: True duals
Well I bet if you were to put a more suitable exhaust on your car, you'd probably be making more power, as well as your friends.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
