3.4 Liter V6 Trans AM Muffler
Old Dec 11, 2008 | 11:56 AM
Birdsong_'89_RS's Avatar
Car: '90 Camaro RS, '94 Miata, '95 F-250
Engine: 5.7 TBI V8, 1.8 PFI L4, 7.5 PFI V8
Transmission: 4L60-OD, 5spd Std, 5Spd Std
Axle/Gears: 2.73 Posi, 4.10 LSD, 3.55 Posi
Which muffler sounds the best on a mildly upgraded engine?
I want it loud but, I don't want it to sound like a pissed off misquito...
By the way, I have a 3.4 Liter GM Performance Parts V6 Crate Engine, Ported and Polished, Heads, Intakes (2.8 V6 for now), and Throttle Body, Crane PowerMaxxx cam (.427/.454) and hydraulic lifters, Accel 19lb Injectors, Accel High Volume Fuel Pump, Accel High Flow Fuel Filter, Accel U-Groove Blister Pack Plugs, Accel Super Stock Plug Wires, Accel Brute Thunder Coil, GM Performance Parts Roller Tip Rockers, Hypertech performance control module, Specter cold air intake, Random Technologies High Flow Cat. I have 2 1/4" pipes from the manifolds back to the cat, 2 1/2" from the cat to the rear...
Old Dec 11, 2008 | 08:25 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: 3.4 Liter V6 Trans AM Muffler
All Trans Ams came with V8s. There isn't much you can do with a v6 to make it sound like most members on this board think a Trans Am should sound. Perhaps you need to post this in the V6 section?
TA
Old Dec 12, 2008 | 12:54 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
probably wouldn't sound to bad with turbo mufflers, they're fairly quiet at idle with a nice deep tone, I've never heard them on a six shooter though.
Old Dec 12, 2008 | 01:39 AM
bigbird89's Avatar
Car: 86 Firebird
TA
Except, of course for the TTA's - the fastest trans ams from the factory. What mufflers did they run?
Old Dec 12, 2008 | 04:37 PM
TA's Avatar
TA
Axle/Gears: 9bolt
Sorry, I stand corrected, but for the rarity, price and performance of TTAs', they are really in a class all their own. I find it highly unlikely that the originator of the thread has ever seen one, let alone owns one.
Turbochargers are remarkable in that they quiet the exhaust note significantly, so using the mufflers from a turbo car will not result in a similar tone at all.
TA
Old Dec 12, 2008 | 06:24 PM
TA
Mine's not the TTA, I have seen one, almost bought it, but I didn't want to spend 10K for a car at the time...I wish I would have now...
Mine used to have a 305 4brl/700R4, the engine 3.4 from my '94 Camaro I had when I was 16 (which I rolled...) the wiring and T5 came out of the '85 Firebird that my T-top roof came off of. I didn't have the money to get another V8 to put in the car...and I couldn't rebuild the original...shot #4 through the valley. Even though I still had to rebuild the 3.4 about a year later...
Old Dec 12, 2008 | 06:37 PM
TA's Avatar
TA
Axle/Gears: 9bolt
Your car will probably be quicker with the 3.4 than it was with the 305, possibly a lot quicker. It's just not gonna sound like a V8 car no matter what you do, I think you're stuck with the pissed off hornets' nest sound.
And I passed on a Turbo TA about 8 years ago for $5,500 because the front fender was dented, the seats were torn, the carpet stained and the headliner was falling down. (sound of kicking myself).
TA
Old Dec 12, 2008 | 10:25 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
When I had a 3.1 V6, it had the closest sound to a V8 I have ever heard. It had stock manifolds to stock y-pipe into a 3" converter then 3" pipe all the way to over the axle then splits into 2 pipes into 24" long 3.5" tailpipes and no muffler. Sounded really good and never got in trouble for the sound. You could only really notice it was a V6 at around 2,500 RPMs or higher.
If you want to go with a set-up like that, but with a muffler. I would get a Dynomax Bullet muffler from Summit Racing. When I put a V8 in my car, I put a Dynomax Bullet muffler in before the axle and with the V8 it was really loud.
Old Dec 13, 2008 | 10:16 PM
I know mine will never sound like a V8, I just don't want it to sound anything like the Civics and Corollas (or that S15 that made me look stupid...)that I smoke on 82nd street...
One of the guys at Unversity Muffler told that I could use a Magnaflow 2.5" 1in 2out muffler, anyone know what that would sound like?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
92camaro350cci
Oct 14, 2015 09:29 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
