installing long tube hookers and oil cooler in the way!!
Old Dec 24, 2008 | 05:23 AM
speedlimit96's Avatar
Car: 92 25th anniversary z28!!
Engine: 5.7L 350
Transmission: 700R
Axle/Gears: stock
hey ya'll i am putting in some hooker header long tube super comps on my 92 350 and the oil cooler is in the way and i was wondering if anybody knew how and where to move it or if its possible to just get rid of it? thanks
Old Dec 24, 2008 | 10:51 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: installing long tube hookers and oil cooler in the way!!
Mine sprung a leak last year, so it was a pretty easy decision to take it off when it interfered with the headers. Just bypass the whole thing with a longer heater hose near the passenger side front suspension arm (two hoses go to a steel line that runs behind the harmonic damper to the other side of the engine). Remove all the hoses and hard lines (they bold to special oil pan bolts) and the oil filter.
When the oil filter is off, the cooler is held on by a very large hex nut under the threads for the oil filter. This is actually a clever adapter tube that holds it all on, just remove the nut/tube and it all comes off. When the oil cooler/adapter tube is off, the oil filter just spins right onto the block where the adapter came off. DONE!
TA
Old Dec 24, 2008 | 12:40 PM
Engine: 5.7L 350
Transmission: 700R
Axle/Gears: stock
thanks man yeah we did all that but the two bolts up in the adapter have to be cut so the oil filter will go all the way on!! what did you end up having to do with the #7 plug? did you have a problem with the spark plug boot rubbing on the header?
Old Dec 29, 2008 | 11:54 AM
TA's Avatar
TA
Axle/Gears: 9bolt
Yes, #7 plug is right against the header tube. I put a heat sleeve on it, so I hope it doesn't burn through, but it's not exactly a great solution, but it'll have to do.
TA
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
