y pipe vs. duals?
Old Mar 23, 2009 | 08:02 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
y pipe vs. duals?
i have both exhaust systems. i have hedman 1 5/8 shortys with 2.5 in true duals with off brand race muffler on the car now. i have hedman 1 5/8 longtubes with 3 in into summit y pipe and 3.5 in pipe into 3.5in dynomax ultra flo bullet. what would make best power?
Old Mar 23, 2009 | 08:17 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: y pipe vs. duals?
The long tubes will make more power, I don't think you'll be giving up much going from a dual to a single, 3.5 is big enough for gobs of power.
Old Mar 24, 2009 | 05:15 PM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
If you are really concerned go with the 4in cat back from mufflex. I am running hedmans with dual 3in going into a dual 3in in to 3in out catback and it flows very well I think. I only have a mildly built 350 though.
LT1Formula
Oct 8, 2015 08:34 PM
zman1969
Oct 1, 2015 11:09 AM
