New Headers... bolt size?
Old Mar 31, 2009 | 10:38 PM
mvd72786's Avatar
Car: 1989 Camaro IROC-Z
Engine: 305ci 5.0L (TBI to carb)
Transmission: manual
I recently removed my exhaust manifold on my carbed (previously TBI) 305. I am installing hedman shorty headers (68470) and stupidly I got rid of all of the bolts from manifold i took off. What size bolts to I need to put the hedman headers on, and are different lengths required for different holes? Also... it looks as though the passenger side header will be really close as far as clearance with the passenger side wheel well and one of the hard cooling pipes... anyone have any issues with these headers? Thanks for all of your help.
Old Apr 1, 2009 | 04:29 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: New Headers... bolt size?
Just go to the auto parts store and ask for header bolts for a SBC. They are a 3/8"-16 thread, with about 1" of threads, and you need 12. They all need to be the same length.
If you just get hardware store bolts, make sure you get ones where the heads will clear the primaries on the headers.
Old Apr 1, 2009 | 10:03 PM
mvd72786's Avatar
great, thanks. I've got the headers on, how close can the brake lines be to the headers without the temperature causing a problem? The headers are not ceramic coated.
Old Apr 1, 2009 | 10:52 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If you think the brake lines are close enough to the headers to be concerned about, post a pic.
As long as they are in the stock location, they should be fine. Brake fluid doesn't boil until 400*+.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
