HEDMAN HEADERS o2 bung ???
Old Apr 6, 2009 | 03:53 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
o.k. i'm looking for headers for my new ride . i like the hedman 68478 headers with the 17478 Y pipe . the question i have is do they an o2 bung on them ? i have been on hedmans web site and drew a blank . anyone know ?
Old Apr 7, 2009 | 05:55 PM
UNCLE TOM's Avatar
Re: HEDMAN HEADERS o2 bung ???
bump , does anyone know ???? thanks .
Old Apr 8, 2009 | 05:26 PM
UNCLE TOM's Avatar
well this is a first , asked a question and nobody knows . no sarcasm intended . guess i'll just get them and see for myself . if i have to i will weld in a bung on the "Y" pipe below the collector . has anyone done that ? installed an o2 sensor in that area , any problems ?
Old Apr 9, 2009 | 05:31 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I have the shortie hedmans with the y-pipe and no, there is not a bung in the headers. I wouldnt put the 02 in the y-pipe, Id rather have it closer like in the collector.
Old Apr 10, 2009 | 10:55 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
I have the same set up on my 91 rs. I had an O2 bung welded to the y pipe just down from the collector. This is what the folks at hedman recommended. Set up works just fine...
Old Apr 10, 2009 | 11:30 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Same setup here. I did install a heated O2 sensor for fear that the stock one would be too far away to stay at temp. Ran it for a few hundred miles with the stock, unheated sensor in. Ran OK but warmup is definitely faster with the heated sensor.
Old Apr 10, 2009 | 01:44 PM
UNCLE TOM's Avatar
thanks for the response , i'll put the bung in just below the collector . i knew someone on this forum had to have run across this problem . will be ordering them this next week . thanks .
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
SMURFN' Z28
Feb 16, 2004 11:00 PM
KYL98
Sep 7, 2003 12:49 AM
TBIformula91
Oct 12, 2002 11:42 PM
