What will I need?
Old Apr 23, 2009 | 04:59 PM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
What will I need?
I have a 1992 Camaro RS 305 TBI, right now it has a stock exhaust. This weekend i am ordering a magnaflow system part #16829, and i am also ordering a magnaflow direct-fit cat part #93456. I am very new to working with exhaust, can someone give me some input on what i will need? Will i need to buy any other parts at all? I am hoping to order everything at once.
Old Apr 23, 2009 | 07:46 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: What will I need?
If everything is direct fit you should only need tools. But we all know how direct fit often goes.
Old Apr 23, 2009 | 09:44 PM
I know it wont be direct fit, the cat im getting is a direct fit but the exhaust im getting is not a direct fit to the cat, thats the only problem i think i will have. How do i get the 2.5 inch outlet of the cat to match up to the 3 inch inlet of the exhaust?
Old Apr 24, 2009 | 05:56 AM
rs coastie's Avatar
Car: 91 camaro rs
Engine: tbi 305
Transmission: 5 speed
You can get a reducer from summit i believe. other than that and tools you should be good.
Old Apr 24, 2009 | 06:29 AM
I tryed to find one on summits site and could only find header reducers, do you have any part numbers for the reducer i might need?
Old Apr 24, 2009 | 06:51 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i would get the 3" magnaflow direct fit cat since it will hook right up to the catback and then use the reducers to mount the cat to the y pipemight be easier after you install everything you may want to have the seems all welded in place too. just a thought. i did
Old Apr 24, 2009 | 07:09 AM
bgood71's Avatar
Car: 89 GTA
I would suggest getting the 3" cat and an adapter to connect it at the y-pipe. You can find the adapters at most parts stores. Other than the adapter you should only need basic tools. A sawzall is always very handy when doing exhaust work, but a hacksaw will work if you don't have a sawzall.
Old Apr 24, 2009 | 07:13 AM
get or borrow a sawzall. i used one and it still took a bit to get through.
Old Apr 24, 2009 | 08:28 AM
Do you have a part number for the 3 inch cat, i looked and only saw a direct fit cat that was 2.5 inches. I already got the exhaust off using a sawzall, and your right it did take a little toget through it.
Old Apr 24, 2009 | 10:01 AM
I found a 3 inch cat, and i think i might go with that becuase later in the year im going to get some headers and it will make it a lot easier then, because the Y pipe will be 3 inches.
Old Apr 24, 2009 | 11:52 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Looking at the photos for the system on Magnaflow's site...
Does the 3" pipe that connects to the cat reduce to a smaller diameter, then go back up to 3" again at the next pipe???
Is there a reason for this?
Old Apr 24, 2009 | 12:28 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Yes, both the cat and the cat back are designed to connect to the stock system, which is smaller than 3".
TA
Old Apr 24, 2009 | 02:13 PM
TA
So you are saying i do not need a reducer?
Old Apr 24, 2009 | 09:00 PM
this is the one i bought MagnaFlow 93441 hooked right up to the cat back. i have hooker 2055's headers. they come with a y pipe that is 3" so everything fits perfect. the best bolt on set up i think. no reducers the cat will slip right over a 3" pipe. i just did complete exhaust a month ago now. headers y pipe cat and catback. any other ?'s just let me know and i will try my best to answer! you may want to cut your old brackets off the old exhaust. i had to reuse the slip in hanger on passenger side and drill a hole in it to mack magnaflow cat back hang there.
