Sidepipes vs. performance
Old May 7, 2009 | 02:20 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
i know there were propably milions of topics regarding sidepipes but i fail to find any that will give me answer to my question.
i want to make sidepipes like this one
and i'm wondering will it kill my performance or will help. my setup is 383 HSR with CompCams CS XR276HR-12.
any sugestions or dyno charts showing numbers ?? i don't care about loudness.
best regards
Old May 12, 2009 | 03:20 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Sidepipes vs. performance
That's Vulcan's car! Those side pipes are just strait pipes coming from the turbos, no mufflers. I'd imagine that there wouldn't be any difference in performance since you're just choosing a different location for the exhaust to exit. If you were changing the length of the exhaust then there would be a little difference.
Your not confusing his sidepipes with the kind that many C3 corvettes have are you? those actually have long inserts inside them to act as mufflers. I have no clue how those affect power.
Old May 12, 2009 | 06:17 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
that looks pretty simple. from the header and a bend to the outside and a cat them the pipe you like. but that pipe will probably require an internal chambered exhaust - like the vette. but those outside pipes actually look like the pipes you see on semi truck's with those long upstanding chrome exhausts, but laying dowm of course.
Old May 12, 2009 | 06:59 AM
WASyL's Avatar
I know that these are only pipes form headres/turbos with-out any mufflers. I'm asking will this kind of setup kill my performance, i do not need to bother about loudness.
Should i go with y-pipe and then go to side with exhaust or make it true dual like going with each other straight form header to the side ??
best regards
Old May 12, 2009 | 07:13 AM
Car: 1990
Axle/Gears: stock
the vette used this setup to increase hp - other than the initial bend the pipes would be straight and if the bend were mandral and free flowing it would not slow down the flow and neither would the straight side pipes.
but they are loud. you will have the exhaust in your ear all the time.
Old May 12, 2009 | 08:08 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
If you're looking for the best possible performance/lowest restriction then you will want to run the true dual setup. This would also be the easiest to do. The factory y-pipe is designed to run back the passenger side. To use it you would need to put a pretty tight bend in it to run the driver's side pipe.
WASyL's Avatar
i know i know but i will be race car so i don't care should i use y-pipe or make it true dual ??
@ 952RS)Ttop - now i use Edelbrock TES headers and their y-pipe but now i know i can get rid of it
best regards
Old May 12, 2009 | 08:35 AM
nicc84camaro's Avatar
Car: 1984 camaro 5.0 305 (stock for NOW)
Engine: 5.0 sbc 305.. soon to be a 5.7 350
Transmission: stock automatic with shift kit
Axle/Gears: stock 3:22 i think?????? =S
i have an 84 camaro that i just got glass packs for and im thinking about running the exhaust right out infront of the rear wheels. Its gonna be a true dual exhaust what do you think about running cherry bombs glass packs with that setup?
Old May 13, 2009 | 12:38 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i had that same idea...it sounded great til i got all the parts and tried to fit it. if you try that setup, you will have no ground clearance. it's easier to run both pipes out on the passengers side and have them dump there. good luck!
Old May 18, 2009 | 02:35 PM
well we are gonna be running a larger tire on the car. and i dont think ground clearence will be to much of a problem. ill keep that in mind tho. thanks.
Old May 20, 2009 | 05:22 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
That car looks beastly. I was wondering though- besides the attachment of the long tube pipe to the headers, what holds the pipe up? It doesn't just hang there does it? Also, how bad is ground clearence? I suppose you need to be careful not to burn your leg on the way out too.
Old May 21, 2009 | 01:34 AM
DBLTKE's Avatar
Engine: LB9, LB9
Idk. I never really noticed. Next time tech him in I'll let you know.
Old May 31, 2009 | 04:45 AM
DBLTKE's Avatar
Engine: LB9, LB9
He came to the track today. There are two hangers that I can see. one right under the door hinges and the other about 8 inches from the end.
Old Jun 8, 2009 | 08:53 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
>Has anyone done side exhausts here? Nascar style? Should give way better perf.!
Old Jun 13, 2009 | 02:42 PM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Engine: 305 TBI, still deciding
Transmission: 700R-4, still deciding
Axle/Gears: stock, 3:73 IROC
Actually the side pipes on the C3 vettes are more restrictive than a true dual setup. Also the sidepipes are connected with some hangers under/on the rocker panel.
Dave
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
