Exhaust header gasket hooker 2055???
Old May 9, 2009 | 09:30 AM
stinger32's Avatar
Car: Trans am GTA 1990
Engine: 383
Transmission: TH700R4
Axle/Gears: stock
I have hooker 2055 headers and I have bought new header gasket set but the ports in the gasket are 1.45x 1.45. The port on the header are 1.33 x 1.55. the old gaskets I recieved with the 2055 are 1.33 x 1.38. If I use the new gasket 1.45 x 1.45 I will have very little sealing left in the upper corners of the gasket. What gasket are you using with hooker 2055? please type partnr so I can check them out.
Old May 9, 2009 | 01:25 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Exhaust header gasket hooker 2055???
This is what i'm using
http://store.summitracing.com/partde...5&autoview=sku
Old May 10, 2009 | 05:02 AM
stinger32's Avatar
Engine: 383
Axle/Gears: stock
ahh so a gasket with round ports works? Isnt it to small in the upper and lower of the gasket or does it burn off?
Old May 10, 2009 | 01:37 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I had the same problem, I got the round port, the 2055's are square port so I had to send them back to swap for the square ports. They should arrive here any day now.
Old May 10, 2009 | 02:08 PM
stinger32's Avatar
Engine: 383
Axle/Gears: stock
2055 square??? Mine are not square more oval but round will fit just fine I think. The ones that came with the 2055 are 1.35 x 1.35 they fit but not the 1.45x 1.45. I'm afraid of using them because there are only 1-2mm left of the gasket in the upper corners.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
billybob6110
Sep 24, 2016 09:50 AM
hectre13
Sep 8, 2015 03:38 PM
formula_novice
Sep 5, 2015 03:58 AM
