dougs lt header install
Old May 16, 2009 | 09:46 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
So far i got the drivers side header i had to jack engine up about 2 inches fits with no issues. the passenger side i am having some issues with it keeps hitting where the a arm bolts up to the frame. Anyone have that issue or is there another way to go about it? i have tried installing the header from the top but doesnt want to go in that way. when i install through the bottom i remove the starter and it almost goes all the way in but come far enough forward. anyone got some key ideas for me?
Old May 16, 2009 | 10:16 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: dougs lt header install
Follow the sticky of this forum, I had to remove my starter and install header and starter together. Had to also install header from underneath after jacking the pass. side motor up and aim the collector towoard the ground and twist the header into a position where it would go in and you also have to remove the exhaust pipe for number 8 cylinder and instaal the pipe back when the header is in position to mount. Need to clearance the a arm mount and the a arm a bit. Just follow the sticky at the top of this forum.
Old May 16, 2009 | 10:37 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
can you leave the spark plugs in or should i just remove them.
Old May 20, 2009 | 08:13 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
finished the whole install with the mufflex y pipe, they sound very nice. ground clearance sucks though i have about a 1 and 1/2 of it. my car is lowered but the springs are really stiff so it has bottomed out yet. i put some pics up later.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
