Long tube clearance issues
Old May 18, 2009 | 09:25 AM
projektz_born's Avatar
Car: 99 Z-28 87 2.8
Transmission: all manuals
i am going to get some long tube headers. i was looking at http://store.summitracing.com/partde...5&autoview=sku or http://store.summitracing.com/partde...5&autoview=sku. i was just wondering if these would be good headers and the bottom clearance issues long tubes might have. I think i read about a few people talked about bottoming out with them. i also heard, but dont remeber which, that certain engine bushings would raise the engine about 1/2 in. would that help with the header clearance? if the dougs arent good there are some hookers i think i might be able to afford. http://store.summitracing.com/partde...5&autoview=sku
Old May 18, 2009 | 09:40 AM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: Long tube clearance issues
i have the dougs long tube heades they fit very good i have new stock mounts. very nice headers. here is some photos..
Old May 18, 2009 | 02:54 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
400hp
Did you have any trouble clearing stock starter with your Dougs headers? Im looking to order some today and that is my only concern.
Old May 18, 2009 | 03:46 PM
400 hp's Avatar
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
Originally Posted by SMKNGTA
400hp
the stock starter dont fit i used a mini starter. and i had to move the knock sensor to the driverside on the motor.
Old May 18, 2009 | 06:33 PM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
just a question about the mini starter, like what brand did you get and what was the cost?
Old May 18, 2009 | 07:17 PM
400 hp's Avatar
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
this is the starter i have jegs. you can use a cheaper one.
http://www.jegs.com/i/JEGS/555/10040/10002/-1
this one looks good.
http://www.jegs.com/i/JEGS/555/10001/10002/-1
Old May 18, 2009 | 07:52 PM
Jekt's Avatar
Car: 1983 camaro
just any 168 will do right? my compression is going to be under 10-1.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
