O2 SENSOR THREAD'S ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
o.k. boy's & girl's , i'm starting another header project . i need to know the thread size for the O2 sensor . i have hedman headers # 68478 & Y pipe # 17478 . no O2 bung , so i will have to weld one on . anyone know the size ? i would like to have all parts ready before start this project . thanks .
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: O2 SENSOR THREAD'S ???
Summit racing sells those, or at least you should be able to find out the size/thread of them. I've put in a few, but either get something more expensive than summit brand or be sure to smother some antisieze on them.
thanks for the lead 82z . i checked summit site , seems like they are 18mm x 1.5 . i was not sure if they were metric or SAE . now i know , thanks again .
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
well you won't find one at lowes , largest i could find there was a 12mm . same at several parts stores . i finally found one at a specialty nut & bolt place . cost $2.75 , 10 bux less and no shipping , did take my time & gas . use your phone or you will run around all over town . not a common size . good luck .
I found the out about lowes last night(I work there) I figured I would have to go to a specialized hardware store, but it's still way cheaper than $10-$12 for a stupid fitting.
