new 3" with x pipe installation
Old Jul 12, 2009 | 08:57 AM
dmason's Avatar
Car: 89 Firebird
Engine: 383 stroker 11 to 1
Transmission: th350
Axle/Gears: 3.73 posi
Just got back my new exhaust and thought I'd share. I bought Jegs universal 3" x pipe kit, about $150. Then some Flowmaster knockoffs available locally but also on web, $35 a piece. Next the install...$125 from the best exhaust guy on the planet. I will upload some pix of the welds later. The Jegs kit is mandrel bent and we did not have to alter the bends, just cut to length. It's not for everyone, loud and a little low, but it's sweet as far as I'm concerned. My neighbors appreciate the headers finally capped on this 11 to 1, 383 stroker. 624 lift roller tends to make some noise.
Old Jul 12, 2009 | 09:38 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: new 3" with x pipe installation
looks nice. be careful about carbon monoxide in the car with those mufflers right under the car. but i presume that you don't sit still very often unless the car is parked.
how much clearance do you have under the car? how about a side view of them?
Old Jul 12, 2009 | 06:24 PM
dmason's Avatar
Car: 89 Firebird
Transmission: th350
Here's a couple of other views including one from the side. That's a 2x4 next to it. Will be mostly track driven except for a couple fun Fridays.....OK I'm almost 50 but I'm not dead! Nothing more fun than pulling up next to a loud rice burner with a fart can.....well you get the picture.
Attached Thumbnails new 3" with x pipe installation-img_0415s.jpg   new 3" with x pipe installation-dsc_0176s.jpg   new 3" with x pipe installation-img_0411s.jpg
Old Jul 12, 2009 | 07:03 PM
HypnoToad's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
is ur car stock height? i have the setup in my sig and it looks lower than yours...looks good though
Old Jul 21, 2009 | 12:45 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
looks good. alil low tho... he coulda done alil better with tucking it up. i have more clearance with mine and it was lowered 1.7" i was running summit universal 3" xpipe with mandrel extensions, 3" headman header extensions, 3" force mufflers, and turndowns. i love how loud it is... sounds like a total beast next to my other 86 305 TA with edelbrock headers/ypipe and flowmaster catback
these cars with true duals sound 1000X better than any single setup ive seen
Old Jul 21, 2009 | 12:52 PM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
Looks good man congrats.
Old Jul 21, 2009 | 01:07 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Which headers are you running? Stock trans cross memeber?
Old Jul 23, 2009 | 01:08 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
by any chance did you move the fuel lines and the filter.
thanks. tony.
Old Jul 30, 2009 | 10:24 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
Im thinking about running the same exhuast! are you using hooker 2210's? so the x-pipe cleared the cross memerber without using hedman s- bends? you just cut the x-pipe down and flanged it and bolted right up?
Thanks, Jerrod
Old Jul 30, 2009 | 11:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Doesnt look too much lower than my old single setup i ran. Heck you may have more clearance than me. Is the car lowered at all?
Looks good but atleast try to run some pipes to the sides of the car abit more to dump it out the wheels. maybe twist the turndown to turn out abit more than 45 degrees. exhaust echoing off the ground makes it very loud inside
11 to 1 383's with big cams are hard to quiet down
Old Aug 3, 2009 | 12:08 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
11 to 1 on a 383 with a mean cam.....that's what I'm talkin' about....yeah!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
drathaar907
Aug 6, 2015 04:20 PM
