heelllllp! bungless!
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
k so im putting a header on my sweet third gen. the header came with down pipe and a race pipe to the resonator. this deletes the cat. however there is no bung for the second o2. would this be a problem for the engine? its the OHV 2200. I do not have to have it inspected.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: heelllllp! bungless!
it will be an issue if the computer is still working, you would need to get an o2 sim or something. Or have a bung welded in.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
not to sure about your situation . but , bungs can be ordered from summits or jegs . or , you can get a nut 18x1.5mm & weld it on . a little grinding & a drill for less than their price . i had to check a dozen places to find one . found mine at a marine nut&bolt place . good luck .
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
I have read that the second o2 in the 99 version of the 2200 is just a warning sensor and not an a/f changing sensor. would installing the header itself warrant a tune though?
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
