What exhaust setup should I go with?
Car: 1991 Camaro RS
Engine: 350LT1
Transmission: Moving on to a T56...for now
First off, to Anthony and Big Al, thanks for the help, so now here is what i have: Its a 4 bolt main 350 out of an 86' Suburban, first question, does anyone see an issue with this swap? Second, Summit has a set of headman headers both full length and shorty, which one do you sugggest? Third, how hard would it to do this swap? What should i get to make it easier? Sorry for the 50 questions but after going through this site there are some really helpful knowledgeable ppl on here I could use help from.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Whats the best exhaust? What are the best headers?
but they don.t get any better than this:
PM me for details
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The '86 Suburban engine will be a flat-tappet cam, and its my opinion those are outdated technology. Today's engine oil lacks the right lubricants to work with flat-tappet cams, so you'll need to constantly use zinc additive to your oil to keep the cam from going flat. Use a roller-cam block, or you can use a roller cam conversion kit in your flat-tappet cam, and enjoy the many benefits of a roller cam.
Shorty headers fit better in our engine compartment, and they come with a y-pipe that bolts right up. Long tubes will give you less ground clearance, and you'll have to custom fabricate a y-pipe, and also long tubes are not 50-state legal for street vehicles. You can get Hooker 1 5/8"'s or Hedman 1 5/8"'s for a mild engine, or Dyno Don or SLP 1 3/4" shorties for a hot engine, and be done with it. Some people claim that long tubes will make a little more power, but really, is the hassle worth it? Shorties drop right in and bolt right up, while long tubes require custom fabrication.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
