Is my cat screwed?
Old Aug 24, 2009 | 06:15 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Is my cat screwed?
I was coming home today and I had decided to hook up my scanner to check on stuff. I noticed my cat temp. was around 700*. At first, I did'nt think anything about it till I got home and noticed there was smoke coming from the cat's flange. Did this thing get too hot?! The car is a 3.1 V6 Camaro. The cat is factory and has been on for 18 YEARS! I have had the car for 15 years. I have no power at all for the last few months or so. I thought it might be smoke from inside the motor. But I can't see smoke making it's way from the engine all the way down the Y-pipes and into the cat just to come outta the flange. The car off and not running so I don't think the smoke was coming from the motor. Whattya think? New cat time?
Ken
Old Aug 24, 2009 | 06:31 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Is my cat screwed?
Either the cat's clogged or you're timing is too advanced/fuel is too lean (which would cause high cat temps).
But the most probable cause is a clogged cat, which will explain the smoke (clogged cat) and the loss of power.
Your best bet is to get a new catalytic converter.
Old Aug 27, 2009 | 02:29 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Originally Posted by ken3983
Is my cat screwed?
Ken
IDK, do you have kittens?
Old Aug 27, 2009 | 02:59 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
Old Aug 27, 2009 | 10:53 AM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
LOL that's hilariously epic.
Sig worthy.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
