I need a catayltic converter for CA
Car: 89 IROC-Z
Engine: 5.7 liter
Axle/Gears: Stock
What kind of catalytic converter do I need to be smog legal in CA? I want a 3" magnaflow what is the part # and where can I find them cheap? 89 iroc 5.7 tpi
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: I need a catayltic converter for CA
1st of all for your car is it only an visual inspection, or does it include s sniffer?
as me being in HI if they by chance they look to see if you have one.
there are lots of quality, hi flow cats. on the market.
or you can take a or a pair of cats and cut them up and weld them around your exhaust for the look. just take your time so they look factory. (I have a tendency to hurry ant the end)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
California requires working, functioning cats, so no hollow cats or shells welded to pipes.
There is a visual test and a sniffer test.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
