Long tube headers/true duals with 2" drop?
Old Oct 22, 2009 | 04:06 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Would it be crazy to install long tubes/true duals with my car being lowered 2"? has anyone been this low with long tube headers? I dont mind scraping **** but i have not idea the clearance with true duals.
My cars stance
Old Oct 22, 2009 | 05:02 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: Long tube headers/true duals with 2" drop?
I have true duals with long tubes, I had to have the piping run under the crossmember for the tranny and then straight back on either side of the driveshaft.. tucked up as close to the floorpans as possible. That's your worst scrapping spot, where the pipes have to go under the crossmember. I have a lowered camaro and 2.5" true dual with longtubes, it has about 2" or maybe 3" of clearance at that point.
Old Oct 23, 2009 | 03:24 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
What type of mufflers are you running? I was considering dual thrush mufflers that dump right near the axle.
Old Oct 23, 2009 | 11:28 PM
Tpx's Avatar
Tpx
I used two 2.5" in/out flowmaster super 40 series. I have the exhaust run under, not over, the rear axle and come up to either side of the spare wheel area, so that the mufflers are under each set of taillights, and they are at a 45 degree angle so they are not sitting straight up or straight down. If I had to do it all over again, I would have run a single 4" system which is just as good as dual 2.5", or close enough to it. These cars are simply not made to handle dual exhaust with full length headers without floor pan modifications or routing similar to stock exhaust systems, but then you'd have to have shortys.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
