o2 simulator?
Old Nov 21, 2009 | 04:27 PM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
o2 simulator?
My problem is, my headers do not have a spot for an o2 sensor. so id have make one, buuut i dont have a welder, i dont know anyone with a welder, and no exhaust shop will touch my car without cats on it. will an o2 simulator work? Anyone have any experience with these things? Appreciate it!
Old Nov 21, 2009 | 05:37 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: o2 simulator?
not really, with as little of inputs as our cars have to tune, you need that o2.....a few options, take the left header out of the car and then get a shop to weld it in, or go buy the o2 bung and go to a utility trailer/welding type shop and ask them to weld it in more than likely they will care less if it has a cat or not
last thing i can think of is to cut out about 3/4" of exhaust pipe, then get a exhaust band clap, they are normaly stainless steel and about 4"-5" long the are used to butt up to exhaust pipes that are the same size without the swedge in it, anyway take that band clamp and drill a hole in it the size of the threds on the o2, get a bolt that matches the thred on the o2 and use it to hold the o2 in the band clamp, then install the band clamp, you want it as close to the collector as you can get and may want to upgrade to a heated o2 also
only other thing is post up in your regional section a post like "mig/flux core welder near (your town) needed" someone on the board should help you out, bring a case of beer for the person as payment
Old Dec 25, 2009 | 11:54 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: o2 simulator?
^^^^^^Agreed
Pyle
May 29, 2004 07:13 PM
white88formula
Dec 22, 2003 11:45 PM
18436572
Dec 14, 2003 10:33 PM
smithtc
Aftermarket Product Review
Dec 8, 2003 10:35 AM
JPrevost
Jul 14, 2003 07:35 AM
