high idle after header install?
Old Jan 10, 2010 | 03:47 PM
fazt4life's Avatar
Car: 1991 camaro z28
Engine: 5.7 350
Axle/Gears: stock 3.23
i just got done installing my edelbrock shorties on my 91 camaro 350. after everything was put back together i started it and everything was normal but then it jumped up to 2300 rpm and sat there. is this becuase the rest of the exhaust is not hooked up after the cats? its just headers then about 4 feet of pipe then it stops. is it idling high becuase the computer isnt use to the lack of backpressure? i need help...
Old Jan 10, 2010 | 10:54 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: high idle after header install?
It is not the computer compensating for the "lack of backpressure".
I am almost certain you forgot to reconnect a vacuum line.
Double, then triple check EVERYTHING.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
