Stock Y-pipe Modifications
Old Mar 12, 2010 | 02:24 AM
8587ta's Avatar
Car: '91 Firebird
Engine: 468 BBC w/ 8-71 blower
Transmission: Th400
Axle/Gears: 9-bolt 2.77
I was looking through a Jegs magazine at the headers and found some shorties. they say that fabrication to the stock y-pipe is required to fit. I was wondering what things need to be done to the stock y-pipe to make these fit. Is it just a matter of replacing the 2-bolt stock flange with a 3-bolt flange? Sorry if this is a redundant question but I did a search and found nothing that really pertained to this. Thanks.
Old Mar 12, 2010 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Stock Y-pipe Modifications
The following won't answer your question, but it may be food for thought: Why purchase headers, which are more free flowing than the OE manifolds, then bottle that flow with an OE Y? For the best performance, headers and matching Y is the best bet.
JamesC
Old Mar 12, 2010 | 09:20 AM
racer7x's Avatar
Car: 85 TA
Something else to keep in mind,I am not sure what you need to do to your pipe but I just modified my stock y-pipe and didn't realize until after I cut it that it is a double walled pipe from the drivers side manifold under the oil pan to the junction with the other manifold pipe.
Old Mar 12, 2010 | 11:33 AM
8587ta's Avatar
Car: '91 Firebird
Transmission: Th400
what exactly is the difference between the stock y-pipe and a new one? Other than new metal and a three bolt flange. How much does it bottle it up, it looks like my Y-pipe is huge, so is a new one just a 1/4inch bigger or what?
Old Mar 12, 2010 | 03:59 PM
JamesC's Avatar
Your OE Y may well be smaller than the outlet of the headers, thus restricting flow. Hooker 2055's, as an example, are 2.5 at the collector (IIRC, your OE set-up should be 2.25), then go mandrel bent to a full three inches, making it possible to run a three-inch in/out converter and a three-inch intermediate pipe. I believe your OE intermediate is 2.75--and nothing will be mandrel bent.
Anyway, you might take a peek at the stickies at the top of the page for more info, if you haven't. And perhaps another member will pipe in.
JamesC
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
