Question about headders
Old Apr 16, 2010 | 09:52 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Ok Im looking into getting a new engine put into my 91 rs and I figured I would get headders along with it...right now im looking at a couple options(engine wise) either an Lt-1 or a custom built 350. My question is will headders with 1 5/8" primaries or work on any 350 block as long as the headders are thirdgen specfic. If not which ones should I use, Im also looking for the best and most affordable headder and y-pipe I can get.Any Info or suggestions?
Old Apr 16, 2010 | 03:15 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Re: Question about headders
LT1 needs a 1 5/8 primary or a D-Port design
I want to say it's hedman pn 68469 by glancing at my old LT1 swap notes.
Old Apr 19, 2010 | 10:05 AM
Engine: 383 stroker
What about a normal Carbed 350?
Old Apr 19, 2010 | 02:53 PM
Pocket's Avatar
Car: 91 Trans Am
The exhaust bolt pattern is the same between SBC and LT1. As long as you have 1 5/8" primaries it will fit both. Why you'd use smaller on either, I dont know
Old Apr 20, 2010 | 10:23 AM
Engine: 383 stroker
What size do you suggest to use then
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
