cats+exhaust for 88
Car: 1988 Firebird Formula
Axle/Gears: 3.42 Posi
cats+exhaust for 88
Hey I just got an 88 formula, the car is not inspected and I am working on fixing it up to be able to pass inspection. The enitre exhaust system is basically shot, holes and leaks everywhere. I need to install new everything from the manifolds back. Im looking for some suggestions. I need pipes up front that will connect to the stock manifolds then go into cat converters then out back into an exhaust system. Im basically looking for a whole setup that will be loud and be able to hook up to the stock manifolds since headers would be more money that I dont need to be spend.
Thanks for any help
Thanks for any help
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: cats+exhaust for 88
This pipe from Hawks will bolt to the manifolds. From there you can get a stock replacement cat or offroad pipe and catback exhaust. Should be easy.
http://www.hawksthirdgenparts.com/ca...enty-pipe.aspx
Hawks can probably get you everything you need to rebuild the whole exhaust.
Here's a cat back and offroad insert that will blot to the MAC crossover pipe nicely.
http://www.macperformance.com/store/...Product_ID=451
http://www.macperformance.com/store/...Product_ID=453
http://www.macperformance.com/store/...ategory_ID=566
Hey thanks that looks like a great setup/idea. I just got this car and just joined this forum and ive already gotten lots of help.
Thanks alot
Thanks alot
