Installing Headman LT's with T-5
Old Jul 14, 2010 | 08:32 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I know I need S extensions. BUT, the headers I have are 1 5/8 primaries and 3" collectors.
Someone recommended me to buy this:
http://www.jegs.com/i/Hedman/500/188...oductId=744777
Unifit 2-1/2'' Tube Diameter
3'' Collector Flanges
2/pkg
Wouldn't I need 3" tube diameter to weld them onto the headers?Similar to this:
http://www.jegs.com/i/Hedman/500/187...oductId=744777
The way I took it is I have to cut the ball flange off the header than weld these on is that correct?
Does anyone have pictures of headman LT headers installed on their T-5?
Anyhelp is appreciated.
Old Jul 15, 2010 | 11:43 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: Installing Headman LT's with T-5
So you wanna go from your 3" collector into a 2 1/2" Y-pipe? What size is the rest of your exhaust (the last half) 2.5-3"?
Either way, there's no problem in doing that.... I would keep your ball flange though because it'll make it alot easier to hook up the system and adjust it at whatever angle you want it. The Hedman ball flange was my saviour!
Check this out.... all parts are for 2 1/2" diameter but going to 3" is just a click away.
Ball Reducers http://www.summitracing.com/parts/HED-21115/
Band Clamps http://www.summitracing.com/parts/SUM-693250/
45* Mandrel Bent Elbows http://www.summitracing.com/parts/WLK-41437/
Magnaflow Stamped Y-pipe 2.5" in 3" out http://www.summitracing.com/parts/MPE-10778/
Magnaflow Stamped Y-pipe 2.5" in 2.5" out http://www.summitracing.com/parts/MPE-10768/
You'll need 2 ball flanges, 1-3 band clamps depending where you want to make your system separate (which makes things easier in the longrun), and at least 4 bent elbows plus the Manufactured Y-pipe.
Working around the manual transmission is a dream compared to the Automatic which has absolutely no room to work!
http://www.bescaredracing.com/iroc/e.../phil_exh1.jpg
http://userpages.xfoneusa.net/~davidlt/exhaust.htm
Take a look on my thread.... https://www.thirdgen.org/forums/exha...y-new-3-a.html
Good Luck
Old Jul 15, 2010 | 01:11 PM
JTNKTZ's Avatar
Engine: 355/350
Honestly, I just want to have the headers, than about 6 inchs of pipe, into a glass pack than dumped. I don't have too much to spend on an exhaust system right now.
So I would have a glass pack on each side.
I also want to stay with 3 inches if at all possible.
I have a welder, but I don't know how to weld so I guess I will be learning? Lol
Old Jul 15, 2010 | 01:41 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
You'll still have to get under your crossmember....
Old Jul 15, 2010 | 02:43 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The collector is gonig to be sharing the same space with the clutch slave cylinder. You're going to have to seriously alter the driver's side header to make it fit. It can definitely be done, but it's not something a BFH can fix.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
